Lifter Noise on 2014 Ram 1500? #1834813
05/26/15 08:40 PM
05/26/15 08:40 PM
N.W. Florida
Fat_Mike Offline OP
Fat_Mike  Offline OP
N.W. Florida
A friend has a '14 Ram with the EDIT: 5.7 HEMI. On cold start up it has a rattling noise that sounds exactly like a lifter to me. It only makes the noise for about a second, then goes away. Doesn't do that when restarted warm, only upon a cold start (sat for about 4 hours when I heard it). I looked for a service bulletin on the web and couldn't find one. He's taking it to the dealer to get checked out sometime this week. Anyone else having this problem, or know of a service bulletin that I couldn't dig up?
Re: Lifter Noise on 2014 Ram 1500? [Re: Fat_Mike] #1834888
05/26/15 10:31 PM
05/26/15 10:31 PM
N
NITROUSN Offline
NITROUSN  Offline
N
A 1500 with a 6.4 hemi?
Re: Lifter Noise on 2014 Ram 1500? [Re: NITROUSN] #1834935
05/26/15 11:28 PM
05/26/15 11:28 PM
N.W. Florida
Fat_Mike Offline OP
Fat_Mike  Offline OP
N.W. Florida
No, sorry, I was mistaken...it's a 5.7. Edited above.
Re: Lifter Noise on 2014 Ram 1500? [Re: Fat_Mike] #1834942
05/26/15 11:37 PM
05/26/15 11:37 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What oil and what filter is he using?
Re: Lifter Noise on 2014 Ram 1500? [Re: NITROUSN] #1835197
05/27/15 12:17 PM
05/27/15 12:17 PM
N.W. Florida
Fat_Mike Offline OP
Fat_Mike  Offline OP
N.W. Florida
I'll have to ask. It has less than 7,000 miles, and he uses the trucks computerized "oil life" system to dictate when he changes oil. Unless there was a something like a 500 mile service, it may have never had the oil changed. I'll find out... Edit: I'm really more interested to know if it's a known/documented problem so he doesn't get BS'd by the dealer when he takes it in. It's under warranty, so they'll fix whatever it is if they take the time to duplicate the problem. Regardless, I'll get the answer to your question.
Re: Lifter Noise on 2014 Ram 1500? [Re: Fat_Mike] #1835214
05/27/15 12:54 PM
05/27/15 12:54 PM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
Most modern day engines seem to be pretty noisy on startup. My wife's 2010 Edge is, My 08 Ram was, we have a few new vans in our fleet at work and they all sound kinda crappy when cold, and fine when warm.
Our 06 beater van at work with 240K on the clock doesn't make a sound when cold though LOL.
68 Barracuda Formula S 340
Re: Lifter Noise on 2014 Ram 1500? [Re: NITROUSN] #1835565
05/27/15 09:41 PM
05/27/15 09:41 PM
IN
ahy Offline
ahy  Offline
IN
I had that on a 5.7 after oil change at a quick lube. The filter had no check valve and let oil drain back. A MOPAR filter fixed it.
Also a slight chance its an exhaust leak/warped manifold that sounds like a lifter. I had a left manifold that would only leak when cold then sealed up. I took I to a dealer and they said manifold leak... new manifold fixed it (over 100k).
Re: Lifter Noise on 2014 Ram 1500? [Re: ahy] #1835918
05/28/15 12:36 PM
05/28/15 12:36 PM
N.W. Florida
Fat_Mike Offline OP
Fat_Mike  Offline OP
N.W. Florida
Wow, who would have thought. EDIT: He just told me that it has its original oil and filter at less than 7K miles. Oil life indicator says it has 15% oil life remaining, which he'll have changed at the dealer while they're looking at this other issue.
Re: Lifter Noise on 2014 Ram 1500? [Re: Fat_Mike] #1836087
05/28/15 04:59 PM
05/28/15 04:59 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
A lot of stuff going on inside that newer engine with the MDS, VCT junk in it so I have heard several almost new trucks with little ticking noises like that at start up.
Re: Lifter Noise on 2014 Ram 1500? [Re: Fat_Mike] #1840357
06/03/15 11:05 AM
06/03/15 11:05 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I can only say it is not typical. Mine does not do that. The recommended oil change interval is 10K. I did that for the first change but now doing it at 8K, same as our fleet where I work.
I did have to have an oil sensor replaced last week that threw a code. I am at just over 22,000 right now.
Craig
Re: Lifter Noise on 2014 Ram 1500? [Re: denfireguy] #1840745
06/03/15 07:43 PM
06/03/15 07:43 PM
N.W. Florida
Fat_Mike Offline OP
Fat_Mike  Offline OP
N.W. Florida
It certainly isn't a noise I would consider to be "normal" either. As I said in the initial post, it sounds exactly like a lifter rattling to me. I'm sure, whatever the cause is, it will be quite difficult to trace down as it only does it when absolutely cold, and only lasts for a second (or so). He hasn't taken it to the shop yet. Once I get some feedback I'll be sure to post the findings.
