NAG1 controller finally on market. Just found this...
#1833058
05/24/15 12:43 AM
05/24/15 12:43 AM
Posts: 2,937 GA
roadrunninMark
GA
I was doing some research on the NAG1 and reading about how people having a rough time with controlling the NAG1 transmission. Well, I just found this site: http://soundgermanautomotive.com/pcs/I don't know anything about this company/ controller yet, but I will try to find out more, including posting on the other sites. Has anyone else heard of this unit/company?
Re: NAG1 controller finally on market. Just found this...
[Re: roadrunninMark]
#1833425
05/24/15 08:19 PM
05/24/15 08:19 PM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
Driveshafts with slips are very common in jeeps etc, shouldn't be an issue to have one made that way.
68 Barracuda Formula S 340
#1833430
05/24/15 08:26 PM
05/24/15 08:26 PM
Posts: 484 Rio Raton
Lenguevo
Wes Hutchinson says goodbye
Rio Raton
I think my Crossfire has a NAG1 tranny.
Straight from 12th grade into junior college Buddy, buddy, buddy, I passed my exam Making me a law enforcement person Got me a gun and a badge, I'm a man
#1833527
05/24/15 11:15 PM
05/24/15 11:15 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
That $1200 doesn't include the transmission, does it?
#1833660
05/25/15 02:16 AM
05/25/15 02:16 AM
Posts: 5,998 Salem
Grizzly
Moparts Proctologist
Salem
Is there something wrong with just grabbing all the OEM computers and transmission from an autowrecker?
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#1833825
05/25/15 01:20 PM
05/25/15 01:20 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Is there something wrong with just grabbing all the OEM computers and transmission from an autowrecker? Quite likely a minefield there. I haven't really looked into it yet. I do know that the engine and transmission controllers communicate with one another. The engine controller also communicates with the body controller for engine run authorization. There are eleventy billion computers in today's cars and they are all interconnected in one way or another.
#1833866
05/25/15 02:06 PM
05/25/15 02:06 PM
Posts: 3,871 Oregon
hooziewhatsit
I'm 100% sure that price doesn't include the transmission. Heck, I'm trying hard to stay under that price with my 46RE controller
[Re: feets]
#1834208
05/25/15 10:41 PM
05/25/15 10:41 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
Is there something wrong with just grabbing all the OEM computers and transmission from an autowrecker? Quite likely a minefield there. I haven't really looked into it yet. I do know that the engine and transmission controllers communicate with one another. The engine controller also communicates with the body controller for engine run authorization. There are eleventy billion computers in today's cars and they are all interconnected in one way or another. There is ABSOLUTELY something wrong with it.....IF you don't insure the tone rings and speed sensors are there also. I went that whole route. It is on my build thread on FBBO in the projects section title "B Body Stiffening"
Driving modern convenience in classic beauty
#1834778
05/26/15 07:58 PM
05/26/15 07:58 PM
Darius
Sacramento, Ca
Another note on this PCS NAG1 controller, it was originally designed to use in the new Gen LX ,LC platform cars for those who were building the GenIII hemis to race. They wanted the transmission to handle massive horsepower etc. I believe the applications we are trying to use it for need more than what the original designers were thinking about initially. Once they started to see the demand for older car swaps they had to regroup. This is purely MY interpretation based on conversations with several folks who have had some exposure to the issues around it. I believe they will develop a product that will increase in demand , particularly once word starts getting around that there is a product available to enable this swap. I have looked HARD for this solution and it appears I must be one of the first to go down this route....at least the first to have it posted on the most visited Mopar Forums anyway. I know I have not seen it in any of the Mopar magazines, but I don't read every one of them either. Most of those editors are stuck in the past anyway.
#1835146
05/27/15 10:53 AM
05/27/15 10:53 AM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
Is the trans up shifted by electrical servos or by hydraulic like the old 727? If elec then why not just use micro switches to up shift and down shift( full manual ). The speed sensor iis inside trans and works with the abs sensors plus main controller. Reason I know the mechanic next door spent two months with the help from the Dodge shop trying to find the problem with a 2011 Charger. The trans would go into limp mode, tried everything, two trans, new sensors, changed tires. Come to find out the previous owner had changed to an SRT8 rear(3.06 ratio) and main controller was programmed for a 2.65, so the sensors couldn't jive and kicked it into limp, even the main engineers from Chrysler couldn't figure this out. Changed back to an original rear and trans worked fine.But chrysler did say the tires had to be within 5% of stock size to work properly(same as changing gear ratio). We think the rear package came with a chip box but was lost with selling the car to dealer to used dealer. As far as using Jeep trans I think they are independent (bolted solid to frame) so no u-joint either, I didn't see the type of slip u-joint you used in your build up pics other than the aluminum piece. Edit; got the original trans and going to pull it down to see if my idea would work.
[Re: cudaman1969]
#1835282
05/27/15 02:46 PM
05/27/15 02:46 PM
Darius
Sacramento, Ca
Is the trans up shifted by electrical servos or by hydraulic like the old 727? If elec then why not just use micro switches to up shift and down shift( full manual ). The speed sensor iis inside trans and works with the abs sensors plus main controller. Reason I know the mechanic next door spent two months with the help from the Dodge shop trying to find the problem with a 2011 Charger. The trans would go into limp mode, tried everything, two trans, new sensors, changed tires. Come to find out the previous owner had changed to an SRT8 rear(3.06 ratio) and main controller was programmed for a 2.65, so the sensors couldn't jive and kicked it into limp, even the main engineers from Chrysler couldn't figure this out. Changed back to an original rear and trans worked fine.But chrysler did say the tires had to be within 5% of stock size to work properly(same as changing gear ratio). We think the rear package came with a chip box but was lost with selling the car to dealer to used dealer. As far as using Jeep trans I think they are independent (bolted solid to frame) so no u-joint either, I didn't see the type of slip u-joint you used in your build up pics other than the aluminum piece. Edit; got the original trans and going to pull it down to see if my idea would work. I am NO expert ,in fact very novice, about exactly how transmissions work, particularly the new computer controlled ones but....I do know that Russell had us save a file of how the thing was working and send it, the computer itself, the rear gear, and the tire diameter when he re-programmed my unit. Obviously all of these components have to line up like the stars for everything to work properly. There was some discussion (mostly talking from Russell) about pressures and signals so I am pretty sure it is a combination of both that actually cause the transmission to shift when it does. I should have this thing re-installed sometime next week so I can report on performance.....or not.
#1835426
05/27/15 05:51 PM
05/27/15 05:51 PM
Darius
Sacramento, Ca
I believe I talked to Chris. At that time, they did not have anything for this swap. This is why we ended up at PCM. In my opinion and experience ,there is no SINGLE source for EVERYTHING required for this swap if indeed you are using a donor car and want everything from that same donor.
#1835434
05/27/15 06:01 PM
05/27/15 06:01 PM
Darius
Sacramento, Ca
I just went to the hotwire site and looked at their kit. It says right on their list of what is included/needed that you MUST have the tone rings AND speed sensors from the rear axle installed. THIS is what I have been telling everyone on every thread I have responded to on two different forums was MY problem! It is EXTREMELY difficult if not damn near IMPOSSIBLE to mount stock tone rings on an 83/4 axle assembly!
#1835506
05/27/15 08:19 PM
05/27/15 08:19 PM
Posts: 4,254 Canada
WO23Coronet
Canada
Has anyone looked into Powertrain Control Solutions? It appears they have a controller that works with the NAG1. Edit: my bad, the original link is for a PCS controller......DERP!
[Re: cudaman1969]
#1835717
05/28/15 12:59 AM
05/28/15 12:59 AM
Posts: 3,871 Oregon
hooziewhatsit
Is the trans up shifted by electrical servos or by hydraulic like the old 727? If elec then why not just use micro switches to up shift and down shift( full manual ). I saw a video of a guy with (probably a GM) transmission he set up like that. Had two (or three?) toggle switches on the dash. For every shift, he had to select the proper orientation up/down, down/down, etc. Every. Single. Shift. No thanks That being said, it's probably feasible, just not practical. If the controllers require the speed sensor and tone rings, I wonder how hard it would be to generate those from another sensor that's easier to mount
[Re: hooziewhatsit]
#1835796
05/28/15 04:55 AM
05/28/15 04:55 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Is the trans up shifted by electrical servos or by hydraulic like the old 727? If elec then why not just use micro switches to up shift and down shift( full manual ). I saw a video of a guy with (probably a GM) transmission he set up like that. Had two (or three?) toggle switches on the dash. For every shift, he had to select the proper orientation up/down, down/down, etc. Every. Single. Shift. No thanks That being said, it's probably feasible, just not practical. If the trans can be shifted by switches that way I would figure out a way to paddle shift it with relays.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Darius]
#1836102
05/28/15 05:35 PM
05/28/15 05:35 PM
cudaman1969
fredericksburg,va
I just went to the hotwire site and looked at their kit. It says right on their list of what is included/needed that you MUST have the tone rings AND speed sensors from the rear axle installed. THIS is what I have been telling everyone on every thread I have responded to on two different forums was MY problem! It is EXTREMELY difficult if not damn near IMPOSSIBLE to mount stock tone rings on an 83/4 axle assembly! There are NO sensors on the rear axel housing or half shafts, the hubs-brakes have abs sensors from where the signal comes from ( explanation from Chrysler). Just went thru all this with the 2011 Charger Edit, the main speed sensor is inside the trans,pull the valve body and servos and there is the hole dead center with a sensor taking the signal off a slotted ring. By the way I have the new third member ass. setting in the floor with half shafts for sale(3.06 ratio) same rear under SRT8s. Make me an offer.
[Re: cudaman1969]
#1836221
05/28/15 09:20 PM
05/28/15 09:20 PM
Darius
Sacramento, Ca
The tone rings were mounted on the end of the axle/1/2 shaft assy on the 07 I personally took them off of. So, yes. they were not on the housing BUT...the sensor mount was on the housing as I recall, that would be the easiest ting to solve. My point is, if you don't figure a way to mount a sensor/tone ring on the rear axle somehow (assuming you are not moving the newer rear assembly over) you are going to have problems. Maybe they have built something into the newer units, yours is 4 years newer than my donor. It would make the swap real easy if the sensor was mounted on the transmission somehow as that is exactly what the PCS controller does.
