Page 4 of 6 1 2 3 4 5 6
Re: Spaceman Spiff's wagon project. [Re: TonyS451] #866010
07/30/14 08:57 PM
07/30/14 08:57 PM
jersey
Spaceman Spiff Offline OP
jersey
I love it!! When is your stroker going to be ready?? I'm building a 520" for my 65 Coronet wagon. Is your engine using a stock block? You are inspiring me to make mine nicer now. Your wagon is amazing!!
Thank you for the kind words.
It's a stock block based stroker, with RPM heads. It's being built by HPMike on this site.
it's going in over the winter, along with the a/c.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Spaceman Spiff's wagon project. [Re: Spaceman Spiff] #866011
08/02/14 02:05 PM
08/02/14 02:05 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Spaceman Spiff's wagon project. [Re: bigdad] #866012
09/01/14 02:58 PM
09/01/14 02:58 PM
jersey
jersey
My friend's son Hanging out in the back.
Re: Spaceman Spiff's wagon project. [Re: Spaceman Spiff] #866013
09/02/14 09:32 PM
09/02/14 09:32 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Changed out the open 3.31's for a 742 case with 3.73's and a sure grip.
Adjusted the second gear band, changed out the destroyed trans mount( tail shaft was shifted over about two inches!) added a Holley 850 vacuum secondary carb, fire core wires, and shorty plugs. Runs great.
Can't wait for Carlisle!!
Just found this thread. Great project! I love wagons. Grew up in a 60 Dart Pioneer. I still have the cast iron pushbutton trans under my work bench So what happened to the 413 and trans? Seems to be a gap between it running good in July 2012 and needing new trans in Jun 2013
Scott
Re: Spaceman Spiff's wagon project. [Re: Scott Carl] #866014
09/02/14 10:04 PM
09/02/14 10:04 PM
jersey
jersey
The 413 popped a head gasket, cracked the block, and heads. Trans was still good.
The engine in it now is a holdover till the stroker is done. The trans i had was a ball and trunion type. This trans is a '65 cable shift with a slip yoke. It was decided that since i was going to use this trans with the stroker, and it has a manual valve body, that we could get rid of the kick down assembly, and move the engine and trans back about 2 inches, and also set it lower in the frame. So to save time when the stroker goes in, all this was done before hand.
Re: Spaceman Spiff's wagon project. [Re: Spaceman Spiff] #866015
10/03/14 10:04 PM
10/03/14 10:04 PM
jersey
jersey
NOS tail light assemblies. ( i have both)
Next week the NOS bumper arrives.
Re: Spaceman Spiff's wagon project. [Re: Spaceman Spiff] #866016
10/16/14 04:20 PM
10/16/14 04:20 PM
Massachusetts
Sneke_Eyez Offline
Sneke_Eyez  Offline
Massachusetts
Sweet!
Those are going to look awesome on there!
1969 Satellite Wagon - G3 Hemi Swap Incoming. | 1969 Coronet Post Coupe.
2002 Intrepid ES | 2009 Ram SLT | 2004 300M Special | 2002 300M Pro Am - Hers
Are you a New England Mopar Enthusiast?
Come check out the revived NorthEast Mighty Mopar at www.northeastmightymopar.com
Re: Spaceman Spiff's wagon project. [Re: Spaceman Spiff] #1832528
05/22/15 11:10 PM
05/22/15 11:10 PM
jersey
jersey
Engine is finally coming together.
She will be running in the next few weeks.
Re: Spaceman Spiff's wagon project. [Re: Spaceman Spiff] #1835589
05/27/15 10:26 PM
05/27/15 10:26 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
And this season's wheels will be...? biggrin
Still one of my faves on the site up
Old, tired, and sometimes broke down. Me, not my car...
Re: Spaceman Spiff's wagon project. [Re: Spaceman Spiff] #1840933
06/03/15 10:44 PM
06/03/15 10:44 PM
jersey
jersey
Keeping the Draglites.... for now...
Need to get a rear done first, i doubt the 8 3/4 will hold up. Then get around to doing the A/C. That'll happen over the winter, when i have more funds.
Shouldn't be long now.
Look for me at the dealership outside Carlisle.
Re: Spaceman Spiff's wagon project. [Re: Spaceman Spiff] #1840950
06/03/15 10:55 PM
06/03/15 10:55 PM
jersey
jersey
Led lighting.
Re: Spaceman Spiff's wagon project. [Re: Spaceman Spiff] #1857732
06/26/15 10:12 PM
06/26/15 10:12 PM
jersey
jersey
Dyno day is tomorrow. Not much time left to prep things before the 3 hour trip to Carlisle. Look for me outside the dealership this year.
Re: Spaceman Spiff's wagon project. [Re: Spaceman Spiff] #1863812
07/04/15 08:01 PM
07/04/15 08:01 PM
jersey
jersey
It made 550+hp and 630+lb ft.
With a performer rpm and a 850 Holley. I'm sure with a better intake and carb, it would pick up a bunch.
Re: Spaceman Spiff's wagon project. [Re: Spaceman Spiff] #1863889
07/04/15 09:33 PM
07/04/15 09:33 PM
Maryland
K
Keepat Offline
Keepat  Offline
K
Maryland
That is awesome power for a cool wagon! Are you drive the wagon to Carlisle.
Re: Spaceman Spiff's wagon project. [Re: Spaceman Spiff] #1863900
07/04/15 09:45 PM
07/04/15 09:45 PM
jersey
jersey
I'm going to trailer it, unfortunately. Engine isn't in yet. It's to much to chance with a fresh package and a 3 hour drive.
Re: Spaceman Spiff's wagon project. [Re: Spaceman Spiff] #1866969
07/08/15 11:38 PM
07/08/15 11:38 PM
jersey
jersey
Fingers crossed, car will be at the dealership @ Carlisle on friday.
Re: Spaceman Spiff's wagon project. [Re: Spaceman Spiff] #1877992
07/25/15 07:28 PM
07/25/15 07:28 PM
jersey
jersey
Re: Spaceman Spiff's wagon project. [Re: Spaceman Spiff] #1954002
11/18/15 11:38 PM
11/18/15 11:38 PM
jersey
jersey
broke the trans two weeks ago. it's back together now.
Re: Spaceman Spiff's wagon project. [Re: Spaceman Spiff] #2061088
04/24/16 10:37 PM
04/24/16 10:37 PM
jersey
jersey
Re: Spaceman Spiff's wagon project. [Re: Spaceman Spiff] #2257443
02/21/17 10:50 PM
02/21/17 10:50 PM
jersey
jersey
3 inch w/ ultraflows.
