intake gaskets. #183197
01/03/09 11:47 PM
01/03/09 11:47 PM
indy
E
eds dart Offline OP
eds dart  Offline OP
E
indy
Finally got the motor out and am starting the teardown.Discovered 6 of the 8 intake port gaskets sucked in or damaged in some way. Last freshened used the Hughes oring type gasket due to having no luck with the fel-pro or Mr Gasket gaskets. I,m pretty sure its the alcohol causing them to shrivel up like they do. Anything else out there that may be more durable? Heads and intake angles are okay. The gaskets are three years old, car started getting hard to start about half way thru the year, ran okay otherwise.
Re: intake gaskets. [Re: eds dart] #183198
01/04/09 12:00 AM
01/04/09 12:00 AM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
have you tryed the Fel Pro Prostock gasket yet ?
comes in 2 sheets to make up what you need.
very good quailty.
Bondo
Re: intake gaskets. [Re: BobsProFab] #183199
01/04/09 12:14 AM
01/04/09 12:14 AM
indy
E
eds dart Offline OP
eds dart  Offline OP
E
indy
Didn,t know they had that. I,ll have to check it out. Go Colts!
Re: intake gaskets. [Re: eds dart] #183200
01/04/09 12:45 AM
01/04/09 12:45 AM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
I have had that problem in the past, I started sealing the gaskets to the intake and lubricating the head side of the gaskets. Before I had just lubricated both sides of the gasket with no sealant at all. Anyway sticking one side of the gasket seemed to fix or at least help the issue a lot, I haven't had a gasket damaged since I started doing it this way.
Re: intake gaskets. [Re: 540dust] #183201
01/04/09 01:05 PM
01/04/09 01:05 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
http://www.jegs.com/i/Fel+Pro/375/1290/10002/-1
heres a link to jegs with the gaskets.
i use the black trim adheasive to glue them to the intake side.
Bondo
