WHAT TORSION BARS TO RUN #183099
01/03/09 10:32 PM
01/03/09 10:32 PM
mo
moparbud Offline OP
moparbud  Offline OP
mo
can any one tell me what torsion bars to buy for my 68 roadrunner drag car i have ladder bar rear and are mopar performance ok summit has .920/.960
Re: WHAT TORSION BARS TO RUN [Re: moparbud] #183100
01/03/09 10:44 PM
01/03/09 10:44 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
To me it really depends on the power. If you have a lot, most guys limit the downward travel to keep the front end down. real "springy" torsion bars for for lower powered applications were the car needs help getting the weight transfer on the back tire. Another issue is a lot of street use and potential oil pan damage. Looks like you have a big block in a B body, this usually works good. I would stay with the 0.960 IMO.
8.30's @3400 lbs
Re: WHAT TORSION BARS TO RUN [Re: moparbud] #183101
01/03/09 10:51 PM
01/03/09 10:51 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i am wondering what spring rate you have on the4 back?
another place to buy torsion bars is P-S-T.com
performane suspension technology montville NJ 07045 800-247-2288
Re: WHAT TORSION BARS TO RUN [Re: blownzoom440] #183102
01/04/09 01:04 PM
01/04/09 01:04 PM
mo
moparbud Offline OP
moparbud  Offline OP
mo
i am not sure what spring rate is on the rear. this is my first ladder bar car. and trying to learn it all. thanks guys for your help. any info or advice is greatly appreciated.
Re: WHAT TORSION BARS TO RUN [Re: moparbud] #183103
01/04/09 01:26 PM
01/04/09 01:26 PM
ELYRIA,OH
ELYRIA,OH
not sure if you can read the chart on the bars rating#.
Re: WHAT TORSION BARS TO RUN [Re: moparbud] #183104
01/04/09 07:31 PM
01/04/09 07:31 PM
Here's a great Web site to learn............Billy recommends having the stiffest bar in the right front and the weakest bar in the left front to get equal tire loading........
Re: WHAT TORSION BARS TO RUN #183105
01/05/09 09:09 AM
01/05/09 09:09 AM
mo
moparbud Offline OP
moparbud  Offline OP
mo
i was told to run the torsion bars the same on both sides. with a ladder bar car. but maybe not. thanks for your help guys
Re: WHAT TORSION BARS TO RUN [Re: moparbud] #183106
01/05/09 04:45 PM
01/05/09 04:45 PM
ELYRIA,OH
ELYRIA,OH
i would noy run 2 different bars.do you have any bars in it now?
are the LCA modefied?
i run 1" bars in mine but i have a lot more weight than you up front it looks like. do you know how fast you intend on going?wheely bars?
Re: WHAT TORSION BARS TO RUN [Re: moparbud] #183107
01/05/09 07:35 PM
01/05/09 07:35 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I would run the 440/hemi resto bars .920 I think the .960 bars will be to stiff for your lightened front end mike
Re: WHAT TORSION BARS TO RUN [Re: Sport440] #183108
01/05/09 08:46 PM
01/05/09 08:46 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
"Stored Energy" is what your looking for and a .920 bar will not do it. You want the newest and the smallest bar you can get your hands on. In a perfect world you want the bar turned all the way up just so the body is just off the bump stops (and that is with the bump stops shaved down to less than an inch thick) You can always control compression and expansion with the shock and limiters.
Just my opinion.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: WHAT TORSION BARS TO RUN [Re: Troy] #183109
01/05/09 08:57 PM
01/05/09 08:57 PM
ELYRIA,OH
ELYRIA,OH
Just my opinion.
if you tell us where to get them i think we would both try them.
Re: WHAT TORSION BARS TO RUN [Re: Troy] #183110
01/05/09 10:26 PM
01/05/09 10:26 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Just my opinion.
While I like the idea of stored energy! Ive seen the effects of to small of bars. The smallest isnt always the best.
Did I ever tell you the story about the 3 bears. mike
Re: WHAT TORSION BARS TO RUN [Re: moparbud] #183111
01/05/09 11:55 PM
01/05/09 11:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m running 30 year old 6-cyl bars and they seem to be working ok.
Re: WHAT TORSION BARS TO RUN [Re: Thumperdart] #183112
01/06/09 12:48 AM
01/06/09 12:48 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
See, Thumper knows the story about the Three bears Too!
As the 6-cyl bars Arent the {thinnest} bars available.
There are {Drag bars} thinnest. And {6-cyl bars} thicker. And {318/340 cyl bars} thicker yet.
So its not always about just getting the Thinnest bars you can get
Its about getting the bars that are more optimum for your combo. mikre
Re: WHAT TORSION BARS TO RUN [Re: Sport440] #183113
01/06/09 01:07 AM
01/06/09 01:07 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The thin mopar performance bars didn`t work as good as the 6-cyl bars do.
Re: WHAT TORSION BARS TO RUN [Re: Thumperdart] #183114
01/06/09 01:07 PM
01/06/09 01:07 PM
mo
moparbud Offline OP
moparbud  Offline OP
mo
yes i do have bars in it now it was that way when i got it. the left is smaller then the right. and i have not run this car yet. and just looking to get the right stuff before i go run it. you guys are great and thanks for your help.
Re: WHAT TORSION BARS TO RUN [Re: moparbud] #183115
01/07/09 06:18 PM
01/07/09 06:18 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Lets talk about the B body first....
B Body are hard because Mopar no longer sells the old P5249156 .840 bars. I would look and see what the after market has. B Body's can be made to work very well but the learning curve is long. You have to have a very consistent engine,trans and rear suspension to be able to fine tune the front suspension. Trying to do this on a fresh chassis is hard to say the least.
Here is a picture of a customer of mine. Chuck Steinbeck has ran this car in D, E and F and has done very well but 10lbs and a 1/2 turn on his shocks makes a big difference. IF I remember correctly these are the some .840 bars.
Re: WHAT TORSION BARS TO RUN [Re: Troy] #183116
01/07/09 06:35 PM
01/07/09 06:35 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
A body cars......
I believe A body's are a little easyer to play with. Shorter wheel base....less overhang on both front and rear plays a big roll. When Darren Smith (last years world champ) was building his Dart we went through about four sets of bars and a few others that were home made. ( ) We played with spring rates, tapers and everything that we could think of. We learned that you can not compare the spring rates of a coil spring to that of a torsion bar. I thought that was strange but we came to the conclusion that the length of a torsion bar and length of a coil spring (if you unwound it) plays a big roll in spring rates. The bottom line was.....for a very long time Darren ran the MP .840 bars and they worked very well.
Re: WHAT TORSION BARS TO RUN [Re: Troy] #183117
01/07/09 06:52 PM
01/07/09 06:52 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
My old street car (iron headed 440 Duster) being a street, strip car, I ran the .870 bars. This gave me good street manners and yet, when I pulled up hard on the front end....with my hands....the front would rise over seven inches!! Most cars will never do that.
The things I do not like about old, used torsion bars (junk yard 6 cylinder bars) is metal has a memory. It has a natural state that it wants to stay in. When you have used bars the memory or the spring rate start to go away. A new "happy" bar, when installed and tighten up wants to raise the front end up but the weight of the car keeps it down. When you launch the car the momentum and the torsion bars try to pick front end up and put more weight over the rear. When you have week bars....the bars don't want to go up....there is no "spring" left in them so you get no help at all.
I will say this, every car is different and acts different. Sometimes older bars do work in a car but I have to ask my self why??
just my
Re: WHAT TORSION BARS TO RUN [Re: Troy] #183118
01/07/09 09:14 PM
01/07/09 09:14 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My OLD 6-cyl bars are working pretty well I would say...WAY better then the thinnest mp bars but, is there another bar out there for my dart that would work better? If so, I might look into it...
