Check My Compression Ratio Calculations .
#182945
01/03/09 08:49 PM
01/03/09 08:49 PM
Posts: 3,076 Renton, Wa.
Classof70Chally
super gas
super gas
Renton, Wa.
I'm ready to take my 440 block in to be decked, (already bored, honed and aligned honed). I am installing Diamond forged pistons and was using their C.R. calculator to figure my static comp ratio. Their number seems a bit high and I was hoping someone smarter than me (not hard to do ) could double check my figures. My numbers are as follows: Bore 4.350, Stroke 3.750, Rod Length 6.760, Gasket Bore 4.500, Gasket Thickness .039, Top Ring Down .240, Valve Relief -4cc, Chamber Volume 84cc, Proposed Piston to Deck Height .005. Diamonds calculator shows that combo adding up to a static CR of 10.89 to 1 . The heads are aluminum (440Source). Thanks.
Re: Check My Compression Ratio Calculations .
[Re: mopowered]
#182950
01/03/09 09:16 PM
01/03/09 09:16 PM
Posts: 17,916 Akron, Ohio
ProSport
Akron, Ohio
I got 10.25 on the Wallace calculator.
[Re: ProSport]
#182951
01/03/09 09:30 PM
01/03/09 09:30 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Just a question, but why run the ragged edge of detonation with 10.25:1 compression in a street only motor?
[Re: Classof70Chally]
#182956
01/04/09 01:09 AM
01/04/09 01:09 AM
Posts: 851 Brisbane Australia
572B1
Brisbane Australia
The diamond calculator rates your motor at 10.1 not 10.89.you put in the wrong info.-4 for dome + 4 for dish. valve reliefs would be a dish not a dome.Try +4 instead of -4 and you will see your compression ratio is around 10.1 to 1 cheers Rob.
[Re: 572B1]
#182958
01/04/09 10:45 AM
01/04/09 10:45 AM
Posts: 16,917 NC
440Jim
NC
Bingo! Ding, ding, ding
With aluminum heads, flat tops, etc. even 11.+ would be fine, IMO. Sleep easy on this one.
