Zeeker heads 440? #327369
05/24/09 06:27 PM
05/24/09 06:27 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Any one know about Zeeker heads?? Ive heard some talk about them, would like some input.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Zeeker heads 440? [Re: steve660] #327370
05/24/09 06:43 PM
05/24/09 06:43 PM
Northeast, Arkansas
Dodgeman67 Offline
Dodgeman67  Offline
Northeast, Arkansas
I know a guy that used to run some on a big inch motor, they must flow really well.
Re: Zeeker heads 440? [Re: Dodgeman67] #327371
05/24/09 07:22 PM
05/24/09 07:22 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I am pretty certain that a zeeker head is the original indy head. Russ was the money and Zeeker was the head guy/pattern builder... I know Mike and Muscle Motors can fill you in on zeeker heads if no one on here can
Re: Zeeker heads 440? [Re: joshking440] #327372
05/24/09 07:32 PM
05/24/09 07:32 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
A guy I talked to the other night bought a set of Zeeker heads and a Zeeker Tunnel Ram. Said he talked to Indy, of course they wouldn't comment on them, which doesnt surprise me.
Re: Zeeker heads 440? [Re: steve660] #327373
05/24/09 11:25 PM
05/24/09 11:25 PM
NW Pa.
KD800X Offline
KD800X  Offline
NW Pa.
I don't think the Zeeker Head was the original Indy Head. The Zeeker Heads were available back in the early to mid 80's. They were a pretty good head in the Day. I knew a couple people that had a set.
I had a friend that was going 8.10's with a 477 ci 2300lb altered with Zeeker heads and tunnel Ram. This was back in 1989 - 1990.
He ended up getting one of the first sets of Indy Heads and Tunnel Ram back in 90 or 91. I don't recall any ties between Indy and Zeeker.
Although I could be wrong.
Re: Zeeker heads 440? [Re: KD800X] #327374
05/25/09 12:24 AM
05/25/09 12:24 AM
fullmetaljacket Offline
From what I've heard, Zeeker sold the pattern to Indy who then elaborated on the design and formed their own production run under the Indy logo.
Zeeker was the only small company back in the day that made aluminum heads available for the BB Chryslers. The Max heads were still the hot ticket for track with the 906's being the hot set up on the street.
Re: Zeeker heads 440? [Re: fullmetaljacket] #327375
05/25/09 08:02 AM
05/25/09 08:02 AM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I ran a set of fully ported Zeeker heads last year and they flow very well.
They are the predecessor of the Indy 440-1s. Indy bought the molds/rights from Zeeker. The only change I know the really made to them was moved the oiling from the standard thru the block to the heads up through one of the rocker shaft bolts to from the back of the block via lines to the back rocker shaft bolts. Other than that they have pretty much the same port design, chamber, rocker off-set, etc.
Actually if you by Harland Sharp rockers for Indy 440-1s the part number has a "Z" in them because they were designed and built for the Zeekers not the Indy -1s. So the rockers are the same. The set I had had the rocker pedestals cut for big lift cams so the shaft didn't fit/sit into a saddle on the head, rather they had blocks that encased the shaft and fit flat on the rocker shaft pedestals.
I heard some had porosity issues but mine didn't. They worked just fine and were a great flowing head.
Here are a few pictures.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Zeeker heads 440? [Re: WadeMetzinger] #327376
05/25/09 08:03 AM
05/25/09 08:03 AM
Tulsa, Ok
Tulsa, Ok
Here they are next to a set of Indy 440-1s
Re: Zeeker heads 440? [Re: WadeMetzinger] #327377
05/25/09 08:04 AM
05/25/09 08:04 AM
Tulsa, Ok
Tulsa, Ok
Exhaust side
Re: Zeeker heads 440? [Re: WadeMetzinger] #327378
05/25/09 09:43 AM
05/25/09 09:43 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
The Zeekers are about the same as the Indy 440-1's. I had a set of bare Zeekers that had never been touched(still new).I sold them to a friend of mine about 2-3 years ago and hooked him up with Todd Marsh. Todd done a real nice job fixing them. The casting is the weak point on the Zeekers.Also be sure to plug the 1/4 in. oil hole in the head and drill a .060-.080 hole for the oil passage.If not they will fill the valve covers with oil. The 440-1 rockers,intake and all work on these heads.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Zeeker heads 440? [Re: fullmetaljacket] #327379
05/25/09 09:47 AM
05/25/09 09:47 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Not to start a huge war, but I think Indy "Stole" the patter. Zeeker became ill and Indy moved forward. Zeeker ended up passing away extremely poor as I understand it...
Re: Zeeker heads 440? [Re: WadeMetzinger] #327380
05/25/09 09:48 AM
05/25/09 09:48 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
the business relation ship between Indy and Loren Zedyke wasnt exactly how its being described..
but ive been asked to leave it alone..
they are great heads..
cheapst
P.s. Loren was an inovator with the 4 link rear suspensions as well..back in the day..
and had major input into what is now known as the
W-5 for smallblocks.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Zeeker heads 440? [Re: joshking440] #327381
05/25/09 10:17 AM
05/25/09 10:17 AM
KYbywayof WV
Frito Offline
Frito  Offline
KYbywayof WV
Loren Zedyke (Zeeker) moved from Hicksville, Ohio to Atlanta area and started a chassis shop with Dave Mosley called APE (Atlanta Performance Engineering). Yes, Loren passed and Dave is bedfast with Alzhimers.
Re: Zeeker heads 440? [Re: KD800X] #1813533
04/27/15 11:48 PM
04/27/15 11:48 PM
Alabama
K
KelbigD Offline
KelbigD  Offline
K
Alabama
Indy stole the design from Zeek! Zeek was a great man and is missed dearly!
Re: Zeeker heads 440? [Re: Frito] #1813534
04/27/15 11:49 PM
04/27/15 11:49 PM
Alabama
K
KelbigD Offline
KelbigD  Offline
K
Alabama
You are correct; Indy Stole the design from Zeek!
Re: Zeeker heads 440? [Re: KelbigD] #1813545
04/28/15 12:02 AM
04/28/15 12:02 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
No way Russ Flatulence(SP?) would ever do such a thing. I've heard over and over he's first class guy??
Re: Zeeker heads 440? [Re: steve660] #1813645
04/28/15 01:53 AM
04/28/15 01:53 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
So Russ STOLE the idea from Loren?.........how do you steal an idea. There are bunches of alum heads out there now. Did all these companies STEAL the idea from somebody else. You see a market and if you can do it better than what's there, you do it. Called business
Re: Zeeker heads 440? [Re: joshking440] #1813999
04/28/15 04:57 PM
04/28/15 04:57 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
This is the story I have heard many times and believe, Zeeker had a small shop not far from where I lived in Indiana, he made and sold cages and chassis's along with the heads, the last time I was in that shop it was occupied by Danny Davis race cars, Danny's dad I think was Jack Davis of Hooker headers.
Joey
Re: Zeeker heads 440? [Re: jake4cars] #1814183
04/28/15 09:53 PM
04/28/15 09:53 PM
Carson City, NV
440sourcedotcom Offline
Carson City, NV
There are also Zeeker aluminum water pump housings out there. Very, very rare but we have seen them.
(apparently there is another thread going on about this now)
Re: Zeeker heads 440? [Re: steve660] #1814255
04/28/15 11:01 PM
04/28/15 11:01 PM
Jerry Kathe Offline
Jerry Kathe  Offline
Fact – ICH did NOT steal anything from LZ…….but the Zeeker heads did inspire Russ to develop the -1s.
