Power Steering Pressure Hose Foam Protector Sleeve #1813076
04/27/15 03:00 PM
04/27/15 03:00 PM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
I'm working on assembling the front portion of my engine which includes alternator and power steering pump. My original power steering hose had a wrap of foam rubber to protect it from rubbing on the frame.
I purchased a replacement hose and found that it did not include this sleeve. Unfortunetly, the original piece was thrown out. I would like to duplicate the piece and I was wondering if anybody could give me a measurement of the wall thickness of the foam.
A picture is included just so you know what I'm talking about.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Power Steering Pressure Hose Foam Protector Sleeve [Re: FJR doc] #1813228
04/27/15 06:28 PM
04/27/15 06:28 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
3/16" to 1/4" wall on the one in my shop. It varies a bit.
Re: Power Steering Pressure Hose Foam Protector Sleeve [Re: FJR doc] #1813261
04/27/15 07:12 PM
04/27/15 07:12 PM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
Thanks ratroaster. I just need to find some foam rubber and make one.
Kevin
Re: Power Steering Pressure Hose Foam Protector Sleeve [Re: ratroaster] #1813586
04/28/15 12:49 AM
04/28/15 12:49 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Give me some dimensions and I'll see what I can find
1/4" wall
Need ID and length
Jim Fillmore
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Power Steering Pressure Hose Foam Protector Sleeve [Re: FJR doc] #1813735
04/28/15 09:54 AM
04/28/15 09:54 AM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
Hi Jim
Thanks for your help. I thought about giving you a call about this. I will measure the diameter of the hose when I get home tonight. I believe that the sleeve would be about 3.5-4.0 inches in length. I sent ratroaster a PM to see if he could check for me.
Kevin
Re: Power Steering Pressure Hose Foam Protector Sleeve [Re: FJR doc] #1813924
04/28/15 03:16 PM
04/28/15 03:16 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
3 1/2" long. The hose measures a tad over 3/4". About 25/32" or .780. 3/4" ID foam should work and be a little snug on the hose.
Re: Power Steering Pressure Hose Foam Protector Sleeve [Re: ratroaster] #1814538
04/29/15 12:59 PM
04/29/15 12:59 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Have some samples coming in the next day or two. Looks like the best option, though pricey is a silicon foam tube. It's 3/4"ID, 1/4"wall, looks like that old low tech foam sleeve, waterproof and tear resistant. I have some of that coming too.
Re: Power Steering Pressure Hose Foam Protector Sleeve [Re: FJR doc] #1814566
04/29/15 02:10 PM
04/29/15 02:10 PM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
I went out to do a test fitting of my power steering pressure hose last night and it looks like it isn't correct for my application. I found a NOS hose for sale that I'm going to purchase. I need to talk to seller to see if the sleeve comes with the NOS unit.
Kevin
