Pull out the pin first, then install the plug, then PUSH the pin back in...
Thanks... minivan... that worked. The pin and outside part are molded together. I had to break them apart. Then install it from the other side. Pretty easy actually.
Just push the pin in by hand or with some small pliers.
Thanks gtx... First had to separate it (see above), it was a new replacement, how you described worked fine once the two pieces were separated. I had to use the big channel locks, it was a tight fit.
smaking it with a hammer and you will need more than another rivet
Yes - I did not think that was a good option either, especially since this is brand new glass with a significant lead time that ships with a truck freight surcharge. So when it looks like I might break something it is time to step back. So, being tired, frustrated, and a little baffled by something I thought was going to be easy I took a breather and put the question out to Moparts which has a collective IQ a bit higher than mine on my lonesome.
Thanks guys.
