Head gasket help #1812499
04/26/15 07:54 PM
04/26/15 07:54 PM
Sunfish Offline OP
Sunfish  Offline OP
I'm getting ready to put my heads on my 94 magnum 360, when I laid the felpro 1008 gaskets on the block I noticed some of the water jacket passages on the gaskets are not as big as the block, do you recommend enlarging them to match the block, or just leave them alone? They look restrictive!
Re: Head gasket help [Re: Sunfish] #1812506
04/26/15 08:07 PM
04/26/15 08:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Leave them be, they are designed to balance the flow throughout the head. So that parts do not get cooled more than others.
Don't be the exception.
Re: Head gasket help [Re: Sunfish] #1812825
04/27/15 02:01 AM
04/27/15 02:01 AM
(1) budget an hour (2) go to www.moparchat.com and scroll down to & click on "circle track chat" then read thru Sanborns' cooling mods that are in a sticky at the top of the page (3) you'll be more informed when you are done.
