Re: smogger 440 tuning
[Re: Hangtowner]
#1811109
04/24/15 07:31 PM
04/24/15 07:31 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
If it is lean surging at a steady higher cruise RPM I would increase the jetting a small amount(.002 to no more than .004) first I would also work on the distributor later to set the curve up so you have between 10 to 18 BTDC at idle and no more than 36 total revved up wth all the mechancal advance kicked in IHTHs
[Re: Hangtowner]
#1811122
04/24/15 08:01 PM
04/24/15 08:01 PM
RapidRobert
wouldn't hurt to note the in hg that the surge starts/ends. No surge when the TQ was on there correct? & no other changes ex the carb correct? I would richen up the carb mains a fair amount to stop the surging then dial in the dist sub systems spot on then final dial in the carb (with an LM1) if available
[Re: DaytonaTurbo]
#1811422
04/25/15 11:01 AM
04/25/15 11:01 AM
RapidRobert
What Daytona said, bump the initial up to 15 & you'll see a dramatic improvement. you'll (then) need to alter the slots to get the total in line but I'd try it as for a start to get things rolling (plus richen the carb as needed). bottom line you want no pinging. Was the only change preceding the lean surge the carb swap? I wouldn't think the street demon would be lean but I dont know that carb. More info needed. Holler back
[Re: RapidRobert]
#1811514
04/25/15 01:48 PM
04/25/15 01:48 PM
dogdays
Follow Cab's advice. Lean surge at cruise means main jetting is a little small. This could be because the engine has a weaker signal. My example, a carb that worked very well on a squarebore 4-hole intake became quite lean when mounted on a spreadbore intake with an open adapter. Open adapter cuts down the signal or pulse strength, pulls less fuel through the jets, results in lean condition.
After you get carb right start on the ignition. In my experience a low compression engine feels much livelier with a quick curve. But don't try to fix a carb problem with ignition.
R.
[Re: dogdays]
#1811553
04/25/15 02:16 PM
04/25/15 02:16 PM
DaytonaTurbo
Manitoba, Canada
True, but spark advance affects fueling. Fueling does not affect advance.
[Re: Hangtowner]
#1821365
05/07/15 10:42 PM
05/07/15 10:42 PM
RapidRobert
The small pressure gauge at the carb is hard to read, but averages 6 psi. yes but what is the psi at the freewway RPM/VAC when it is surging? And it was fine with the prior carb, & it was a freeway cruise (not exactly a WOT demand). I'd still say it's a carb issue (lean) or psi issue right at the carb (filter/orifice) that's restricting flow/making it lean if the carb internals needle/seat/floats etc are letting it flow enough which wouldn't normally be a problem unless some system is acting up inside the carb
