Re: Holley jet flow chart?
[Re: sshemi]
#1808435
04/21/15 10:11 AM
04/21/15 10:11 AM
BradH
"Somewhere" I saw a some a couple of jet flow charts, but I remember comparing them and the #s weren't in synch w/ each other and didn't bother to keep the info. I don't know if it will help, but I posted THIS CHART on http://racingfuelsystems.myfunforum.org a ways back. If nothing else, you could calc areas for the jet diameters and ballpark it by looking for a 10% increase in area to start with.
[Re: sshemi]
#1808668
04/21/15 03:30 PM
04/21/15 03:30 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I dont have the tools to measure the hole of them. You don't need to measure them. Holley jets are based on flow, not hole size. But to get you close, use the chart posted above, see what actual drill size is of the jets you HAVE. Add 10% and see what jet you NEED based on that calculation. You will still have to tune it, but this will get you close. Figuring a 10% increase in area, will be more accurate than just a 10% increase in drill size. Monte
[Re: Monte_Smith]
#1808765
04/21/15 05:43 PM
04/21/15 05:43 PM
BradH
BradH: "... you could calc areas for the jet diameters and ballpark it by looking for a 10% increase in area to start with." lewtot184: "i figure the square inches of opening on the jets and then multiply the percentage of increase or decrease i want." Monte_Smith: "see what actual drill size is of the jets you HAVE. Add 10% and see what jet you NEED based on that calculation.... Figuring a 10% increase in area, will be more accurate than just a 10% increase in drill size." Uhhh... didn't we all pretty much just tell the OP the same thing? Well, at least he got a consistent response.
[Re: sshemi]
#1810089
04/23/15 12:48 PM
04/23/15 12:48 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
92s from the beginning. Put in 97s pri and 98s sec. Seems to work ok but i only got to test drive a couple of runs then the transmission gave up:-( What are your idle and Hi speed bleeds.
[Re: sshemi]
#1810192
04/23/15 03:02 PM
04/23/15 03:02 PM
Posts: 6,389 nielsville, minn.
quickd100
nielsville, minn.
That doesnt make sence??? Guy at holley said every nr up is 2% increase??? The average mean flow of a #92 is 1150.0 cc;s per minute. The average men flow of a # 94 is 1260.0, #97 is 1440.0 and #98 is 1500.0. That's straight off the Holley Sheet.Dave
[Re: sshemi]
#1810842
04/24/15 12:13 PM
04/24/15 12:13 PM
Thumperdart
State of confusion
No clue there then and this is new to me so time to observe and learn.
