1986 318LA #1807948
04/20/15 06:11 PM
04/20/15 06:11 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
What year did the 318 go to a roller cam?
Re: 1986 318LA [Re: elmor353] #1807957
04/20/15 06:23 PM
04/20/15 06:23 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Mid 85 but only 2bbl ones.
Don't be the exception.
Re: 1986 318LA [Re: Supercuda] #1808690
04/21/15 04:01 PM
04/21/15 04:01 PM
scratchnfotraction Offline
85 cars got roller cam #302 heads carb then TBI
trucks got roller cam TBI 318 in 86-87
truck 360 tbi went roller cam in 89 with #308 heads
85-86 trucks got roller blocks with flat tappet cams 2v & 4V carbs.
all the roller gear swaps over to a roller block to convert a pre-mag LA engine.
early stock roller lifters used a solid PR with non oil thru roller lifters, 90-91 they went to hollow PR and oil thru roller lifters--getting ready for the magnum engine in 92
Re: 1986 318LA [Re: scratchnfotraction] #1808756
04/21/15 05:35 PM
04/21/15 05:35 PM
dogdays Offline
dogdays  Offline
My fail-safe source of 318 roller engines is Fifth Avenues. There were at least two, maybe three+ model years with rollers, and they didn't get driven hard.
R.
Re: 1986 318LA [Re: scratchnfotraction] #1808912
04/21/15 08:52 PM
04/21/15 08:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
With the sole exception of the 81 Imperial there was NEVER a 318 CAR with TBI.
In cars 2bbl is roller cam, 4bbl is not, from mid 85 till end of production.
Re: 1986 318LA [Re: Supercuda] #1808930
04/21/15 09:06 PM
04/21/15 09:06 PM
My goof there. I forgets no TBI 5th aves and such.
man, cant remember when the last time I saw a 81 IMPERIAL either
Re: 1986 318LA [Re: elmor353] #1809034
04/21/15 10:46 PM
04/21/15 10:46 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Mods, can this be put in the archive/Best Of?
A great question and a great answer for reference!
