working out these bugs is a pain!
so far working on her when I can...
removed gas tank, cleaned out the sludge, re-coated it. installed new electric fuel pump.
rebuilt the holley carb.
removed the valve covers to sand blast and paint.
pulled intake removing hydrolic lifters cleaning them.
cleaned plugs re-gapping.
removed fan blade to install plastic shroud.
removed all 4 wheels, car would not move; brakes were rusted and locked up - all are cleaned now working.
wheel bearings grease looked like a rope substance it was so thick - now repacked.
trans pan removed - checking filter which was new fluid smelled fresh.
changed engine oil due to regulator problem of too much gas.
removed trans inspection cover, finding out the torque convertor bolts were all out and rubbing against flywheel - now are tight.
passenger door hinge was frozen - now oiled working.
power steering pump changed out, old one not working. both new lines added.
project now is the gear box I'm changing due to old one leaking and not working.
then on to the electrics, no horns, no blinkers, one headlight works, no fan speeds, no speedo, no fuel gauge, no wipers.
that goes to say No Driver either!@%*^
