2006 5.7 hemi problem #180666
01/01/09 06:03 PM
01/01/09 06:03 PM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
Motor is out of a 300M and I believe is the 4-8 motor where the cylinders shut down if not needed.
When I turn the motor over with the coil unplugged, I carry 200# compression on all 8 cylinders. But when I RUN the motor at an idle, on number 4 cylinder, none of the rockers are moving. But they do moving when hand cranking motor. Pulled head and #4 cylinder is oil soaked. It appears there are solenoids that control oil flow to every other cylinders and this cylinder has a solenoid for it. WHAT IS WRONG AND what should I do. Give me the old iron. That I understand.
Re: 2006 5.7 hemi problem [Re: TrueTripleX] #180667
01/01/09 09:27 PM
01/01/09 09:27 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
There are 8 coils. Check for the right oil viscosity/weight. http://www.allpar.com/mopar/new-mopar-hemi.html
Re: 2006 5.7 hemi problem [Re: earlybee] #180668
01/02/09 01:29 PM
01/02/09 01:29 PM
Ball Ground GA
Ball Ground GA
I am aware of the 8 coils, I am talking about what appears to be 4 solenoids in what us oldtimers would call the valley pan area. And the oil issue does not explain why ALL the rockers work at hand crank, but when running, number 4 rockers are NOT working
Re: 2006 5.7 hemi problem [Re: TrueTripleX] #180669
01/02/09 01:39 PM
01/02/09 01:39 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I believe the when you turn it over by hand the rockers work because you do not have enough oil pressure to activate the solenoids. You have enough when you crank by starter. I don't think it should work at idle. Like it was stated before you need the proper oil. If it is too thick it will activate the deactivation solenoids to soon Matt
Re: 2006 5.7 hemi problem [Re: MattW] #180670
01/02/09 02:30 PM
01/02/09 02:30 PM
Ball Ground GA
Ball Ground GA
But why does this only affect ONE of the solenoids and not the other 3? As I mentioned it is only on the number 4 cylinder. Could that solenoid be bad and is there a way to test it? And final question, if it is the oil and assuming the solenoid is good, do I need to change the lifters on number 4 (I forgot to mention that I bent push rods on that cylinder) along with the push rods only? FYI these lifters are $200 EACH.
Re: 2006 5.7 hemi problem [Re: TrueTripleX] #180671
01/02/09 03:38 PM
01/02/09 03:38 PM
houston texas
gremlinsteve Offline
houston texas
the solenoids work the oil flow to the lifter. those 4 cycl have lifters that are differant than the none mds cycl.
the lifter has a bleed hole in it. basicly it dropp pressure. craks the exhaust valve open and will not open the intake valve.
i suggest replacing the lifters to that cycl. also replace the solenoid to the cyl.
check that the motor is running the 0-20 oil also. anything greater in viscosity and the mds solenoid will not work right. but that does not explain why the others are not acting up.
is it setting codes? p0300? p0304?
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: 2006 5.7 hemi problem [Re: TrueTripleX] #180672
01/02/09 03:39 PM
01/02/09 03:39 PM
houston texas
houston texas
send me your contact info also...i think i have some of those lifters laying around. i have at least one solenoid also..
steve
