Re: Towing with a 03 4.7 ??? [Re: Kindafast] #1802715
04/13/15 09:55 PM
04/13/15 09:55 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I just traded in my 2002 Ram quad cab and I towed about 5500#'s. My '02 was a 4.7 A/T and 3.55's.I would suggest not using the OD on the trans towing that much trailer.I pulled a open trailer with my 71 Demon on it and it did just fine. I think you are at 6700#'s max tow weight.Use a weight distributing hitch and plan on going slow.
Nautilus Racing-
Re: Towing with a 03 4.7 ??? [Re: Kindafast] #1802812
04/13/15 10:52 PM
04/13/15 10:52 PM
Maryland
regularjay Offline
regularjay  Offline
Maryland
Go for it, make sure your brakes are good but you'll be O.K. Everyone seems to forget that probably millions of guys up until 8-10 years ago towed with crappy sup-250HP trucks and everyone survived. Sure it'll be slow and use a bunch of gas but really, heavy trailers aren't some "new" thing people have been towing more weigh with less power for a very very long time. Sure, a 600HP 1000ft-lb diesel would be a better way but it for sure ain't the only way.
79 Lil Red Express - I'll finish it someday
94 2wd Ram 1500 5.9 Donor for...???
78 CJ7 4.2 with Clifford Cam, Holley 390, 4" on 33's
1992 W250 Cummins
2013 Ram 4X4 Hemi Crew Express
2005 Ex Cab Dakota 4x4 4.7 Daily Driver
1993 2wd Ramcharger 5.2/auto
Re: Towing with a 03 4.7 ??? [Re: Kindafast] #1803431
04/14/15 06:16 PM
04/14/15 06:16 PM
Seaford, Va
Kindafast Offline OP
Seaford, Va
Thanks guy's
6.50 @105.26
Re: Towing with a 03 4.7 ??? [Re: regularjay] #1803463
04/14/15 06:49 PM
04/14/15 06:49 PM
Lehigh Acres, Florida
rickstershemi Offline
and when something does go wrong, it can go very wrong......can it be done (sure).....should it be done (NO)
Rickster
