Re: Carter 4327s primary venturi cluster question
[Re: p d'ro]
#1804469
04/15/15 10:08 PM
04/15/15 10:08 PM
Posts: 4,310 Prospect, PA
BSB67
Prospect, PA
I'm with Lew, not sure how it would work without the tubes.
Here is a secondary booster from one of my 4327S carbs.
"....I will find a monk that will grant you total consciousness on your deathbed..." Do I really want that????????
[Re: BSB67]
#1804653
04/16/15 01:07 AM
04/16/15 01:07 AM
Posts: 1,584 MD
p d'ro
MD
i really appreciate you posting that. I guess the ones on my core were messed with or the tubes were crusted in the base and I missed it but I doubt all four tubes would have come out. Bummer! Regarding total consciousness, Bill Murray got it in Caddyshack. "So Ive got that going for me, which is nice."
[Re: NANKET]
#1805454
04/17/15 08:22 AM
04/17/15 08:22 AM
BSB67
Prospect, PA
I looked at a 4327 I have apart, no tubes on these either, they look like the ones in your picture. 4327 dated H6, still had the tag on the screw, car was pretty original.
I would be real hesitant to put parts from an Eddy into a real AFB. That is interesting. Mine is a little different in a couple of other aspects as well, when I look closely.
[Re: NANKET]
#1805481
04/17/15 10:30 AM
04/17/15 10:30 AM
Posts: 1,584 MD
p d'ro
MD
I would be real hesitant to put parts from an Eddy into a real AFB. OK, thanks. Now I am really confused. Mine had tag as well (dated A6) and was very difficult to get apart. I would be naive to think that it had never been apart. The guy from Mike's Carbs says some don't have it and says "It will simply pass through the hole in the venturi from accelerator pump pressure." I will slap it together and give it a go.
