Carter 4327s Edited SECONDARY venturi cluster question
#1802708
04/13/15 09:45 PM
04/13/15 09:45 PM
Posts: 1,584 MD
p d'ro
MD
Should this have some plumbing coming out the bottom like newer Edelbrocks or should it be this way? It came off this way. Thanks pete oops. Cant add pics from my cell? Will upload soon. Basically no piping coming out from bottom holes.
Re: Carter 4327s primary venturi cluster question
[Re: p d'ro]
#1802787
04/13/15 10:42 PM
04/13/15 10:42 PM
Posts: 1,584 MD
p d'ro
MD
So this is not good I assume. Maybe one tube out of large hole called acceleration tube? Neither had one??
[Re: lewtot184]
#1803168
04/14/15 12:54 PM
04/14/15 12:54 PM
Posts: 1,584 MD
p d'ro
MD
see if you can find a "parts" edelbrock 1405 and use the secondary clusters out of it. Wow, thanks for the tip. I did not know they were interchangeable. I have a 750 performer on my car now. I wonder if that would work?
[Re: p d'ro]
#1803984
04/15/15 06:49 AM
04/15/15 06:49 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I was told by the seller of my rebuild kit that some AFB secondary venturis did not have down tubes. Has anyone else seen this? Very possible, I'd try the carb first before swapping parts about. Carter made several hundred different AFB's for OEM applications over time.
"I think its got a hemi"
[Re: p d'ro]
#1804045
04/15/15 10:56 AM
04/15/15 10:56 AM
Posts: 3,913 usa
lewtot184
usa
I was told by the seller of my rebuild kit that some AFB secondary venturis did not have down tubes. Has anyone else seen this? i don't know how they could draw fuel out of the well without a tube. pm 62maxwagon for some details. he has parts and refurbishes carbs. he'll probably know.
[Re: lewtot184]
#1804083
04/15/15 12:28 PM
04/15/15 12:28 PM
gdonovan
Oakdale CT
i don't know how they could draw fuel out of the well without a tube. . Tube is mostly for emulsion since it has holes in the sides, the vacuum from the booster venturi would have no problem sucking the fuel up from the well.
[Re: gdonovan]
#1804095
04/15/15 12:41 PM
04/15/15 12:41 PM
Posts: 3,913 usa
lewtot184
usa
i don't know how they could draw fuel out of the well without a tube. . Tube is mostly for emulsion since it has holes in the sides, the vacuum from the booster venturi would have no problem sucking the fuel up from the well. how does the carb siphon fuel if nothings in the fuel supply? can you sip a coke thru a straw without the straw in the coke? maybe i'm missing something here and somebodys going to have to draw me a picture?
[Re: p d'ro]
#1804100
04/15/15 12:47 PM
04/15/15 12:47 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The tube is the hole in the casting. The brass tubes you think are siphoning fuel are not there for that purpose. They are there to mix air with the fuel (emulsion). To use your Coke analogy it's like sipping Coke with a hole in your straw.
[Re: p d'ro]
#1804139
04/15/15 01:37 PM
04/15/15 01:37 PM
Supercuda
About to go away
About to go away
up yours
I forget, it has been almost 30 years since I fooled with an old AFB, I run the E brock version these days. Someone with the FSM for your year/model might be able to look at the carb section and answer.
[Re: p d'ro]
#1804176
04/15/15 02:20 PM
04/15/15 02:20 PM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
see if you can find a "parts" edelbrock 1405 and use the secondary clusters out of it. Wow, thanks for the tip. I did not know they were interchangeable. I have a 750 performer on my car now. I wonder if that would work? I wouldn't , you'll be potentially transferring the reason that particular carb is a POS to the replacement carb.
[Re: JohnRR]
#1804368
04/15/15 07:09 PM
04/15/15 07:09 PM
Posts: 3,913 usa
lewtot184
usa
see if you can find a "parts" edelbrock 1405 and use the secondary clusters out of it. Wow, thanks for the tip. I did not know they were interchangeable. I have a 750 performer on my car now. I wonder if that would work? I wouldn't , you'll be potentially transferring the reason that particular carb is a POS to the replacement carb. ????
