Re: 700 N/A vs 700 Blown
[Re: hudsonhornet7x]
#1800720
04/10/15 11:20 PM
04/10/15 11:20 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
If they both make the same power, I would take the one that made the most torque at the given torque/HP curve I desired.
11B40
#1800745
04/10/15 11:49 PM
04/10/15 11:49 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
My head says the blown motor will have more torque, a milder idle and properly tuned, be more street friendly. My heart says nothing sounds as good as a high compression engine with a lopey idle, and that anything else sounds boring.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#1800749
04/10/15 11:51 PM
04/10/15 11:51 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
My head says the blown motor will have more torque, a milder idle and properly tuned, be more street friendly. My heart says nothing sounds as good as a high compression engine with a lopey idle, and that anything else sounds boring. I agree, while I like the blown or turbo better power wise, nothing sounds like a nasty motor with a big lopey lope cam. But a blower motor with extreme blower surge at idle is pure sex also
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
#1800814
04/11/15 12:37 AM
04/11/15 12:37 AM
Posts: 4,254 Canada
WO23Coronet
Canada
On paper they should be equally as quick, but realistically the blower motor would get there easier and would be a lot more fun to drive. I also think the blower motor would be quicker with a not so ideal set up (who ever has a perfectly dialed in set up). I'd go forced induction
[Re: WO23Coronet]
#1800820
04/11/15 12:42 AM
04/11/15 12:42 AM
Posts: 1,541 USA
hudsonhornet7x
USA
Thank you guys for the help, believe it or not this is a high school shop class project, you might have read about it in Chrysler Power. We have a chance to build a supercharged engine and it will be a first for us.
Picture this: 6.4 " Hellcat esque" blown motor, caged, General Lee fresh off the rotisserie.
Think Galen would certify that as a 1 of 1 lol.
#1800928
04/11/15 10:40 AM
04/11/15 10:40 AM
Posts: 11,994 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The blower motor should have a flatter torque curve and hold more torque longer so it would have an performance advantage in the real world. Is budget an issue? The blower stuff will take more coin than the N/A.
Master, again and still
[Re: Evil Spirit]
#1801028
04/11/15 01:02 PM
04/11/15 01:02 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
My head says the blown motor will have more torque, a milder idle and properly tuned, be more street friendly. My heart says nothing sounds as good as a high compression engine with a lopey idle, and that anything else sounds boring. I agree cos we've all seen too many slower than they should be blower motors and a FEW fast n/a cars.........
[Re: Thumperdart]
#1801043
04/11/15 01:41 PM
04/11/15 01:41 PM
Posts: 43,096 Bend,OR USA
Cab_Burge
I would think of how much added strain driving the blower makes on the motor, compressing air driven off the crankshaft takes HP and adds strain on every part of the motor, before making the final decesion. As far as turbos I've been told that( by racers who use them) they do add additional concerns off the back side of the motor so I guess there are no free lunches. Adding boost into a motor definetily makes more power easier per C.I. than N/A motor do.
#1801127
04/11/15 05:00 PM
04/11/15 05:00 PM
Posts: 4,205 New York
polyspheric
New York
And as we all know, that rilly kewl sound is why we build motors...
Boffin Emeritus
[Re: Cab_Burge]
#1801282
04/11/15 09:22 PM
04/11/15 09:22 PM
Posts: 8,160 Plymouth, MI
Blusmbl
Plymouth, MI
I would think of how much added strain driving the blower makes on the motor, compressing air driven off the crankshaft takes HP and adds strain on every part of the motor, before making the final decesion. As far as turbos I've been told that( by racers who use them) they do add additional concerns off the back side of the motor so I guess there are no free lunches. Adding boost into a motor definetily makes more power easier per C.I. than N/A motor do. It can take 100+ extra horsepower to drive a supercharger even on a mild 600-700hp street engine, so the entire rotating assembly is going to see additional stress from the cylinder pressures over an n/a motor. However, for the same displacement the n/a motor would have to spin at higher rpm, which requires more expensive valvetrain components. Both are cool. I like torque so I prefer big blocks, or supercharged/turbocharged smaller displacement engines.
[Re: Pale_Roader]
#1801632
04/12/15 12:51 PM
04/12/15 12:51 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
That wasn't a Shivvy, that was a Ram with a 420" Gen III Hemi.
Mopar to the bone!!!
[Re: Blusmbl]
#1801641
04/12/15 01:03 PM
04/12/15 01:03 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Cranks see maximum stress near TDC. Because boosted motors run less timing, the cranks actually see a lot less stress vs. a N/A motor.
[Re: dizuster]
#1801795
04/12/15 05:04 PM
04/12/15 05:04 PM
Cab_Burge
Cranks see maximum stress near TDC. Because boosted motors run less timing, the cranks actually see a lot less stress vs. a N/A motor. Let see, the boosted motor has forced a lot more air and fuel into the cylinders and that ignites and makes a lot more power than a N/A combination would so how can that posiibly make less stress? BTW, I have made motor with Roots super charger that made peak HP (496 C.I.street hemi on pump gas 927HP) at 7300 on pump gas and N/A motors on race gas that made peak 730 HP( 471 C.I. wedge) at 7300 RPM. Same RPM for peak HP, which one has the most stress on the rotating components in your mind? Insert whistling Emotioncon here with smiley face after it. On your deal with the turbo where it does not drive the turbo off of the crank and it does not gain boost directly proportionally to RPM, depending on the throttle and gear it is in, it will not have the same stress per RPM as a supercharge motor will with all other things being the same. HP makes stress, less is less.
#1801911
04/12/15 08:36 PM
04/12/15 08:36 PM
dizuster
Oakland, MI
Cab we're talking 700hp NA to 700hp boosted right? Not 927hp boosted, vs. 730hp N/A. I think it's fairly obvious that more power means more stress, but you're trying to compare apples and oranges to make a point. What about 730hp N/A vs. 730hp Boosted both at 7300rpm. Which one has less rotating assy stress? I bet the N/A motor has 35 degree's of timing in it, and I bet the boosted motor has 25 degree's in it. Less peak pressure but holding it over a longer period of rotation will make more power with less stress on the parts. If I shove a bunch more air/fuel in the cylinder, and light it off late (low timing), it can keep burning nice and long at low pressure to keep pushing on the crank as it rotates. N/A has to light off what little air/fuel it has early (lots of timing), and that tries to push the crank out the bottom of the block from the pressure spike. Same reason in principal why parts get damaged when the motor detonates. That early pressure spike near TDC is HARD on parts. Below is a really good graph. The red line is a 11:1 4 banger motor at 45 degree's of timing which made 156 ft/lbs. The blue line is the same motor with 15 PSI of boost, and only 25 degree's of timing but it made 213ft/lbs. Notice that the peak pressure is the same on both. (Meaning in this particular case they would have similar crank stress). This is a good example of what I was talking about above... that the boosted motors can hold the pressure on the crank longer/later to make power. No additional peak pressures (stress) at TDC... but picked up 35% in torque. However if we were just looking to make the same 156ft/lbs you can imagine with lower timing how low the peak would be on the boosted motor to make the same power. This is what I'm talking about why boosted motors are less stressful on parts then they're NA counterparts at the same power level. BTW... the link below is a good read if anyone wants to dive into the topic further. Ottoboost_2 by wright2305, on Flickr https://www.physicsforums.com/threads/high-compression-turbocharged-engines.646362/
#1801970
04/12/15 09:43 PM
04/12/15 09:43 PM
72Swinger
Nebraska
Doesn't the cylinder pressure required to make the power equal the same in the end? Kinda a wash IMO? Difference is one crank has more leverage on the crank snout,blower pulley, than the other. I like turboes more betta...
#1802296
04/13/15 11:44 AM
04/13/15 11:44 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The blower motor can make the power at a lower engine speed which is the key here. To make the 700hp N/A will usually take more RPM. Stress/load goes up much faster with increased RPM than it does with increased HP. So the stress/load may be the same at the same HP and RPM between the 2, but additional RPM adds additional stress and load.
[Re: WO23Coronet]
#1802339
04/13/15 01:05 PM
04/13/15 01:05 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
On paper they should be equally as quick, but realistically the blower motor would get there easier and would be a lot more fun to drive. I also think the blower motor would be quicker with a not so ideal set up (who ever has a perfectly dialed in set up). I'd go forced induction boosted would give you a drivable/usable car, whereas 700N/A would give you a super high compression, big bumpy cam not streetable car that would require high octane, expensive high stall and most likely need steep gears to work.
[Re: dizuster]
#1802482
04/13/15 04:21 PM
04/13/15 04:21 PM
Cab_Burge
Let me try to set this up so it does not come off as arguing for argument sakes, I'm of the opinion that any time you use a power adder of any sort your adding stress into the motor by artifiscially (SP?) inducing more power than the motor will make normally. As far as HP per C.I. you can make a very small C.I. motor make a lot of power with enough compression and RPM, you can make a much larger C.I. motor make the same HP at a much lower RPM with a lot less strees on the components due to the lower RPM. As far as adding boost and reducing timing your reducing the timing the stay out of detonation, the inside combustion chamber temps. are much higher with the added pressure of the boost and will detonate a lot sooner than having the pressures less, hence you retard the timing to stop detonation. The blown Hemi mtor I referrenced like 33 degrees total timing with 7 lbs of boost at 12 % underdriven on CA pump swill, I had tried 28 to 35 degrees and it like 33. We switched the fuel to C16 and reverse the pulleys so the motor would overdrive the blower 13%, I reset the timing to 25 degrees and made a pull. The motor made peak HP (1027 HP) at 6500 RPM with that timing and 12lbs of boost, but is was on the edge of detonation and stop gaining power at 6500 I reset the timing up 2 derees to 27 and the motor started into detonation at 6200 RPM so we stop the pulls at that time. Maximum effeincy can be tuned for any combination, large C.I. and slow RPM will make a lot more torque than a smaller motor making the same HP at a higher RPM, especially with boost Is that chart you link to for a small europen deisel motor, Otto cycle? If so you and I both know that diesel motors that self ignite have to have stronger cranks, rods, pistons and blocks to make them live at the same power levels as a gas motor makes, correct? If it isn't for a deisel motor forgive me for seeing and thinking of Dr. Otto Deisel, or Dr. Deisel Otto (which ever his name was ) the inventor of diesel motors and theory. My last pump gas street stroker motor in my Duster made 727 HP at 6700 RPM and 540 ft. lbs at 3500 RPM and had 735 FT lbs at 4500 RPM. It was a blast to drive and did require some maintenance on the valve springs do to using a moderate solid roller cam on the street, if I had added a blower to a smaller C.I. motor to make the same HP I'm sure it would have required more maintenance and better parts to live at that power level Lots of ways out there to have fun
#1802542
04/13/15 06:19 PM
04/13/15 06:19 PM
Posts: 2,629 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Rudolf Diesel (who invented the diesel) worked at Deutz as did Nikolaus Otto (who gets the credit for the current 4 stroke engines).
2011 Drag Pak Challenger
[Re: Mr.Yuck]
#1803188
04/14/15 01:17 PM
04/14/15 01:17 PM
Thumperdart
State of confusion
On paper they should be equally as quick, but realistically the blower motor would get there easier and would be a lot more fun to drive. I also think the blower motor would be quicker with a not so ideal set up (who ever has a perfectly dialed in set up). I'd go forced induction boosted would give you a drivable/usable car, whereas 700N/A would give you a super high compression, big bumpy cam not streetable car that would require high octane, expensive high stall and most likely need steep gears to work. Nah, 12.1.1 comp.,5000 plus vert, .680-.660 solid roller and 4.11 gears here and it drives like a kitten till you stab the happy pedal then it`s a tiger. Great torque off idle and pulls past 7 grand with ease and I drive it more than just to car shows. N/A all the way for me till something changes between my ears and eyes.
[Re: Thumperdart]
#1803319
04/14/15 03:36 PM
04/14/15 03:36 PM
Mr.Yuck
Brookeville, Md
On paper they should be equally as quick, but realistically the blower motor would get there easier and would be a lot more fun to drive. I also think the blower motor would be quicker with a not so ideal set up (who ever has a perfectly dialed in set up). I'd go forced induction boosted would give you a drivable/usable car, whereas 700N/A would give you a super high compression, big bumpy cam not streetable car that would require high octane, expensive high stall and most likely need steep gears to work. Nah, 12.1.1 comp.,5000 plus vert, .680-.660 solid roller and 4.11 gears here and it drives like a kitten till you stab the happy pedal then it`s a tiger. Great torque off idle and pulls past 7 grand with ease and I drive it more than just to car shows. N/A all the way for me till something changes between my ears and eyes. haha you are not going to take a 700hp on a 150 mile road trip you can however do it w/ a 700hp boosted motor. It is what it is.
[Re: Mr.Yuck]
#1803334
04/14/15 04:09 PM
04/14/15 04:09 PM
Thumperdart
State of confusion
NEVER ASSume anything and I have driven it that far for a local movie shoot in the middle of bfe..........
#1803393
04/14/15 05:38 PM
04/14/15 05:38 PM
Posts: 1,845 Tampa
DusterDave
Tampa
One downside the blown combo will have is the increased weight on the front end. I'd still choose the blown engine if its a street driven car.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: Mr.Yuck]
#1803407
04/14/15 05:50 PM
04/14/15 05:50 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
On paper they should be equally as quick, but realistically the blower motor would get there easier and would be a lot more fun to drive. I also think the blower motor would be quicker with a not so ideal set up (who ever has a perfectly dialed in set up). I'd go forced induction boosted would give you a drivable/usable car, whereas 700N/A would give you a super high compression, big bumpy cam not streetable car that would require high octane, expensive high stall and most likely need steep gears to work. Nah, 12.1.1 comp.,5000 plus vert, .680-.660 solid roller and 4.11 gears here and it drives like a kitten till you stab the happy pedal then it`s a tiger. Great torque off idle and pulls past 7 grand with ease and I drive it more than just to car shows. N/A all the way for me till something changes between my ears and eyes. haha you are not going to take a 700hp on a 150 mile road trip you can however do it w/ a 700hp boosted motor. It is what it is. my old big block made over 700 and drove 400 miles a day at Drag Week without a single problem and it was like 5 years old at that point and my current Hemi is around 600+ and it very mild and I already did Drag Week with it also
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
#1803628
04/14/15 10:04 PM
04/14/15 10:04 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
If forced induction was that hard on parts, the OE's wouldn't have been doping it since the 30's.
You think Gm is going to put out a 650 supercharged cadillac if they think it will be hard on parts and come back for warranty work?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
#1804414
04/15/15 08:38 PM
04/15/15 08:38 PM
Blusmbl
Plymouth, MI
The OEM's put in the correct parts to survive supercharged applications. An LS9 chevy has forged pistons, while the n/a LS7, with a 600 rpm higher rev limit, has cast pistons in it instead. Cylinder pressures are highest at lower engine speeds, and this problem is exacerbated by adding a supercharger. Dizduster brings up a good point regarding timing but that is only one piece of the puzzle.
[Re: hemi-itis]
#1804867
04/16/15 12:16 PM
04/16/15 12:16 PM
Thumperdart
State of confusion
Not if they're slow..............looks funny in that case, kinda like a wing on a honda.
[Re: Thumperdart]
#1805046
04/16/15 04:37 PM
04/16/15 04:37 PM
Posts: 4,254 Canada
WO23Coronet
Canada
Both are cool, N/A or supercharged. What I take from this is 700 forced induction HP will be easier to live with, better on fuel etc. Not saying that 700 N/A HP can't drive long distances or on the street regularly (ThumperDart and sixpackgut both proved it), but again a forced induction engine will do it a lot better, likely less maintenance and likely be faster with a compromised (streetable) set up. Look at Dizusters Savoy, 9 sec whip that idles like it's almost stock! No crazy gears of convertor needed
