Re: 69 a-body rear springs [Re: StrkrDart69] #1799969
04/10/15 12:57 AM
04/10/15 12:57 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Originally Posted By StrkrDart69
WOW that is high. shock
confused I've seen a few that set up high...but that's way too much to correct with spring hangers and lowering blocks. shruggy It may be cheaper to check into the HD springs... twocents
...FAFO...
Re: 69 a-body rear springs [Re: 2abodymcodes] #1800069
04/10/15 08:57 AM
04/10/15 08:57 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
wow that's high! the shackle is pointing in the wrong direction. should go like this \ relative to the rear
Re: 69 a-body rear springs [Re: mikemee1331] #1800082
04/10/15 10:10 AM
04/10/15 10:10 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
The 002 and 003 SS spring would be correct for nostalga type drag racing. They are designed to transfer the weight on launch onto the rear - especially right rear. On launch, the rear body will rise a little and the front a little more. They will need to be used something like 9" slicks and put the snubber up against the floor. /6 t-bars, 90/10 front shocks will also help and all period correct.
For stock replacement, the factory parts and shop books listed different springs for different combos. Something like this:
1969 A-body leaf springs
6 170 3004 580
6 225 3004 581
6 225 B-HT 3004 582
6 225 B-FB,C 3004 585
8 273 Val, Da 3004 583
8 318/340 V,L 3004 584 new
8 318/340 B 3004 588 new
8 383 B,L 2808 677
HD ex. 383 2808 532
HD 383 2808 678
Leaf packs varied from as few as 4 leaves to as many as 6 on both sides.
Stengel Bros carries a good selection (made by Stanley in the US) and you can drill down to see the specs of the ones they repop. However, if you're buying them and expect them to be visually correct, find out if the interleaves and clamps are different style than original. So for most correct looking, the clamps might have to be changed out.
http://www.stengelbros.net/Plymouth-Leaf-Springs_c_226.html
http://www.stengelbros.net/Dodge-Passenger-Car-Leaf-Springs_c_194.html
Re: 69 a-body rear springs [Re: mikemee1331] #1800098
04/10/15 10:44 AM
04/10/15 10:44 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Initially that was one of the reasons I went to the longer B Body hangers since they were headed in the wrong direction. Later replaced the shackles to sliders. twocents
...FAFO...
Re: 69 a-body rear springs [Re: skicker] #1800553
04/10/15 08:01 PM
04/10/15 08:01 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
it almost looks like you have truck springs on there! maybe that's what 'heavy-duty' relates to? is it possible to remove a leaf? shruggy
Re: 69 a-body rear springs [Re: 2abodymcodes] #1800733
04/10/15 11:36 PM
04/10/15 11:36 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi,is this cuda finished? bumpers, full interior,full fuel tank, sparetire, jack, all window glass? both front spring hanger bolts NOT tightened until car on ground and loaded? try another pic with a 225lbs buddy sitting in trunk with loose front spring bolts and lets see how it sits. ron
Re: 69 a-body rear springs [Re: 1969ronnie] #1800835
04/11/15 01:13 AM
04/11/15 01:13 AM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
back glass is not in the car. rear bumper doesn't weigh much. 240 pounds hanging on the rear of the car makes very little difference.
Re: 69 a-body rear springs [Re: 2abodymcodes] #1850664
06/16/15 08:51 PM
06/16/15 08:51 PM
Shelby, Ohio
2
Shelby, Ohio
The interior, gas tank spare and jack,and all the glass is in. Still sets way too high. I'm going to remove the mopar performance springs and put my stock original springs back under it.
Re: 69 a-body rear springs [Re: 2abodymcodes] #1850836
06/17/15 12:20 AM
06/17/15 12:20 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Keep removing leafs until it sits right, over time if it sags add back.
