3M undercoating for beach/salt/sand #1798954
04/08/15 11:09 PM
04/08/15 11:09 PM
NY NY
3
340duster340 Offline OP
NY NY
has anyone used the 3M undercoating on their truck? i want to take my new ram on the beach, but want to protect it.
i was quoted at 600 to do the frame, differentials, floors and inner wheel wells....seems high, but nobody else around here even offers the service.
thanks,
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: 3M undercoating for beach/salt/sand [Re: 340duster340] #1799036
04/09/15 12:45 AM
04/09/15 12:45 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I never used their undercoating, but one option to consider is a truck bed liner. It can even be tinted to match the trucks color. It's easy to clean too.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 3M undercoating for beach/salt/sand [Re: 340duster340] #1799562
04/09/15 05:51 PM
04/09/15 05:51 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
You can do it yourself and save hundreds. www.monstaliner.com
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: 3M undercoating for beach/salt/sand [Re: DusterDave] #1800752
04/10/15 11:55 PM
04/10/15 11:55 PM
IN
ahy Offline
ahy  Offline
IN
I think your best protection is a pressure wash of the underside after beach use. Undercoat can protect from rock chips to some degree but not so good for rust protection. Sometimes undercoat (and bedliner) can get moisture underneath and hide rust.
Also don't forget to air down your tires... last time I ran on a beach 12 PSI was about right. With higher pressure I did not move. An air tank to increase pressure for the ride home helps.
Re: 3M undercoating for beach/salt/sand [Re: 340duster340] #1800950
04/11/15 11:17 AM
04/11/15 11:17 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Yep, stay away from the beach. Saltwater will get everywhere and pressure washiing won't get it all out.
Save yourself thousands that way, enough to buy a beater truck for beach running.
Seriously.
Angry white pureblood male
Re: 3M undercoating for beach/salt/sand [Re: ruderunner] #1801090
04/11/15 03:27 PM
04/11/15 03:27 PM
Orange Park FL.
LilRed7879 Offline
LilRed7879  Offline
Orange Park FL.
I am sure you can find someone in NY but I have heard that oil coating is the preferred method to prevent rust from all the salt during winter. You have to get it done every year but it eliminates some of the concerns of stand undercoating.
This site explains it - http://nhoilundercoating.com/blog/rust-proofing-vs-oil-undercoating/
David S.
Part Time Owner
Dodge Connection
www.dodgeconnection.com
904-209-9388
Re: 3M undercoating for beach/salt/sand [Re: 340duster340] #1801307
04/11/15 10:27 PM
04/11/15 10:27 PM
NY NY
3
NY NY
oil coating won't work with the sand kicking up.
i have accepted the fact that a) salt will rust my truck, but also b) that my truck will be worthless any ways when it actually becomes an issue (say 7-10 years) as by then cars will run on unicorn farts and get 100mpg and anything with a v8 will be worthless.
i will post some pics when i get the undercoat on. first going to wash with this salt terminator product for prep and then spay the 3m shutz all over!
