New 3:55 gears always howl. True or False?
#1795037
04/02/15 04:34 PM
04/02/15 04:34 PM
Posts: 1,185 Nanaimo, BC
NOrrTH
Nanaimo, BC
I had a very respected Mopar guy who runs a tranny and rear end shop rebuild my 489 pig. He advised against the 3:55 gear because he said they don't cut the teeth the same way as they used to and they ALL howl now regardless of brand. It just affects the 3:55 gear set for some reason. He also said that if I was determined to go with the 3:55, the best thing to do was find NOS factory gears.
Anyway I went ahead and they do howl around freeway speeds. I thought I could live with it but the gear reminds me its there over and over again. So now I'm thinking of 3:73...
Anyone else heard of this?
'71 GTX N96 auto 3:55
'74 Challenger 440+6 4spd 4:10
'71 Duster 340 auto 4:10
Re: New 3:55 gears always howl. True or False?
[Re: NOrrTH]
#1795038
04/02/15 04:50 PM
04/02/15 04:50 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
That's BS. The gears aren't set up properly. He's blowing smoke at you. Need to find someone else that knows what they're doing, and talking about. When i first started out as an auto mechanic, i worked at a shop doing differentials, here in my city.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: hemi71x]
#1795039
04/02/15 04:59 PM
04/02/15 04:59 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
[Re: NOrrTH]
#1795043
04/03/15 12:59 AM
04/03/15 12:59 AM
RapidRobert
I submit that they were a set that was setup wrong & howled for a prior owner & he is (now) attempting to pawn them off on you to cut his loss(es). EDIT Competent and crooked are two different attributes & they ain't mutually exclusive. The tip off (to me) on this deal was him blaming the numerical ratio choice as being the problem
[Re: hemi71x]
#1795045
04/03/15 01:09 AM
04/03/15 01:09 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
That's BS. The gears aren't set up properly. He's blowing smoke at you. Need to find someone else that knows what they're doing, and talking about..
[Re: TheTieWrapKid]
#1795050
04/03/15 01:47 PM
04/03/15 01:47 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Any gear can be noisey if there's a problem. Problems are not always with the gears themselves, or even from the chuck. But - if there are not other issues, and they are broken in proerly, no gear ratio in and of itself will be noisey.
[Re: moper]
#1795051
04/03/15 02:30 PM
04/03/15 02:30 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
This is what I was thinking. My friend who built my 489 case 3.55 gears is very picky about how it's set up. Even when I was putting my 8 3/4 together he didn't want me to consult anyone but him. He was extra particular about how the gears were broke in, especially with a 489 case that has a crush sleeve. IIRC he states 20 minutes of light street driving and 2 hours of rest to cool down for about 3 cycles, always use an 85w gear oil or higher, and no burnouts/towing for the first 500 miles.
[Re: mopars4ever]
#1795054
04/03/15 07:50 PM
04/03/15 07:50 PM
NOrrTH
Nanaimo, BC
I broke in my "new" set very easy. I don't want to mention any names, but this guy is very wealthy, has lived mopars since he was a kid, owns about 30 of them now, some of which are worth hundreds of thousands, drag races and is a bit of a Mopar celebrity in these parts...and he runs a transmission shop which has been doing rear ends for decades. My point is, he's not some Craigslist back yard mechanic, hack. Now I'm really scratching my head
[Re: an8sec70cuda]
#1795056
04/03/15 11:48 PM
04/03/15 11:48 PM
Posts: 15,304 Omaha Ne
TJP
Omaha Ne
The other common Fallacy is that the lower you go the more they will whine, BULLS$heet I say. I have run gear sets as low as 5:13's in a street car that were quiet as a church mouse. I've run 3:91's, 4:10's, 4:30's, 4:56's, 4:88's and 5:13's. ALL QUIET noise wise WHEN SET UP PROPERLY. IF one is talking about special RACE only sets that could be a different story.
