lifting body to install engine from below
#1783717
03/19/15 04:07 PM
03/19/15 04:07 PM
Posts: 7,358 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
This worked OK, to remove the engine but as you can see, the cherry picker's legs are in the way. To get the engine back in, I was going to make an extension out of angle iron to get the cherry picker out away from the body. I was going to bolt some angle iron to the bumper mounts and then a piece of angle iron in between those to lift against. I've seen people do this before. I need a recommendation on what size and thickness of angle iron to get. 1 1/2" wide? 2" wide? 1/8" thick? 1/4" thick? Any suggestions? Thanks
Re: lifting body to install engine from below
[Re: JMCFAN]
#1783720
03/19/15 04:39 PM
03/19/15 04:39 PM
Posts: 7,358 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
http://store.uscartool.com/uni-lift-unibody-front-end-lifting-tool.html
That's basically what I want to do but I'm going to use angle iron. I just want a recommendation of what size to use. I used a spare set of bumper brackets to install the engine in my Challenger. I've seen people use angle iron before.
[Re: DaytonaTurbo]
#1783723
03/19/15 04:51 PM
03/19/15 04:51 PM
Posts: 7,358 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I just don't know how strong angle iron is. Is 1/8" thick strong enough if I'm going to make the arms roughly 30" long?
Thanks Gary...
[Re: ebodyseast]
#1783726
03/19/15 05:38 PM
03/19/15 05:38 PM
Posts: 2,065 CA
crackedback
CA
2x2 .125 angle 2x2 .125 square tube 2 bolts/nuts Drill 6 holes I had to lift the engine and car with this set up because of the engine/car angle wouldn't allow it to settle at K frame. Long bolts run in, picked up, more blocks under pan. No problems at all.
[Re: crackedback]
#1783728
03/19/15 08:51 PM
03/19/15 08:51 PM
Posts: 2,404 Lee Co. Fla.
5carguy
Lee Co. Fla.
2x2 .125 angle
2 bolts/nuts
Drill 6 holes
[image]http://img.photobucket.com/albums/v655/crackedback/70%20Dart%20340%20EK2/Engineinstall.jpg[/i
This is a nice install.Inexpensive and easy to make.Good job.
[Re: skicker]
#1783730
03/19/15 10:12 PM
03/19/15 10:12 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I think I used 1/4 but I can check when I get home Saturday. 2 pieces coming off the bumper bolts (both bolts) with a piece going across with 2 bolts on each side. Not the best picture but you get the idea how they were turned.
Careful, your character's showing!
[Re: mopar346]
#1783731
03/19/15 10:13 PM
03/19/15 10:13 PM
mopar346
I gotta learn to take better pictures.
[Re: mopar346]
#1783733
03/19/15 10:47 PM
03/19/15 10:47 PM
Posts: 477 mr norms avenue
5571
mr norms avenue
I have a four post lift, I was thinking of doing the install with that, lowering the car over it. I can see how you can get access to the K frame bolts at ground level, but how are you guys getting to holding up the trans? When you have to raise the car to get the trans brace? Wont the engine tilt back on the motor mounts and hit the firewall?
67 hemi GTX silver 4spd, 70 cuda convert 340 4spd, 71 cuda 340 4spd (Curious Yellow, white billboards/interior), 70 Mr Norm's Challenger 440 4spd
[Re: 5571]
#1783734
03/20/15 12:00 AM
03/20/15 12:00 AM
Posts: 1,800 South Lyon MI
sleddinfool
South Lyon MI
I put my engine and trans in from the bottom. Looks like Burdars garage may be a little different then mine though. I jus happened to pick up a 2500 pound atv winch new in the box for $20.00 at a garage sale. Bolted it to a 2x8 piece of ash, supported the roof rafters/joist with 2x4's to the floor. used another 2x4 between the frame rails under the radiator area and hoisted away.. Worked very well. I used 2x6s stacked on a set of snowmobile dollies and strapped engine and trans down to the dollies with a ratchet straps. I had engine and trans in in about 15 minutes. Kevin
71 gtx.....
