1992 transfer case oil #1778598
03/13/15 12:09 PM
03/13/15 12:09 PM
Kentucky
dfsmopars Offline OP
Kentucky
Helping a friend swap a trans on a '92 1/2 ton 4x4. If we top off the oil in the transfer case does it take ATF+4 for that year?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: 1992 transfer case oil [Re: dfsmopars] #1778599
03/14/15 04:51 AM
03/14/15 04:51 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
The short answer is likely Yes. Which engine?
Ideally, you look it up from the Owner's Manual or Factory Service Manual.
Here is a link to look up capacities and correct lubricant specifications online.
Amsoil Capacities and Lubricant Guide
Re: 1992 transfer case oil [Re: D_C] #1778600
03/14/15 02:31 PM
03/14/15 02:31 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
FSM says the NP241 takes Dexron, and the NP205 takes GL-5.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
