Re: American Power Train 5 Speed Install
[Re: ringo440]
#1778056
03/12/15 09:57 PM
03/12/15 09:57 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
I would immediately pick up the phone and call AP and ask for Gray. He will help you out.
383, Hemi 4-Speed, AlterKtion, D60
[Re: ringo440]
#1778060
03/13/15 09:38 AM
03/13/15 09:38 AM
Posts: 819 On the open road
Hrtbkr
On the open road
I cut the tunnel near the front on the passenger side and a friend formed a patch panel and welded it in. I've been told by others you can bump that area out enough without cutting. There were also issues with the pilot bearing staying in place. It would move after the engine warmed. I used Loctite black (from Graingers) to keep it in place.
While outside on the turnpike
They got this new hit tune
Where thrills become as cheap as gas
And gas as cheap as thrills
[Re: 71birdJ68]
#1778063
03/13/15 01:49 PM
03/13/15 01:49 PM
Posts: 235 ga
ringo440
ga
Talked this morning with passion , o.d. has a six to eight weeks wait time I hope I can get the guy to wait. What rear gear are you running?
[Re: Lefty]
#1778065
03/13/15 06:46 PM
03/13/15 06:46 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I got a mew tko600 kit from kiesler still sitting in the boxes... From my research, you don't even need the 4 speed hump to use them in a b-body... that was clearance for the shifter. Like mentioned you can clearance the tunnel some. I imagine e-bodies are the same too. My perfect rust free floor pan was already cut years ago in the tunnel, otherwise I would wait and go passion also, but this kits already here and paid for.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
