727 trans build part 1 #17777
10/17/05 11:58 PM
10/17/05 11:58 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Since the new motor went in I have noticed some slippage out of my 727 so I've decided to rebuild a core that I had in corner of the garage for a few years. The core is a 71 unit from a std performance 440 car. The first step was easy, taking the trans apart. We will soon find out if it will go together as easy as it came apart.
I started out by bagging and labeling all of the small parts. Next was a trip the the hot tank.
All of the boars were checked for ware and scoring, then honed with a crossbuff.
The pointer in this shot points to a 1/8th hole I drilled into the return line channel to feed additional oil to the sprag.
stay tuned for part 2
Re: 727 trans build part 1 [Re: ccdave] #17778
10/18/05 12:31 AM
10/18/05 12:31 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
keep em comin, i might try this myself soon....
Re: 727 trans build part 1 [Re: 493_DART] #17779
10/18/05 01:17 AM
10/18/05 01:17 AM
Me too.
Re: 727 trans build part 1 #17780
10/18/05 01:27 AM
10/18/05 01:27 AM
Central TX
roe Offline
roe  Offline
Central TX
Me too.
me too
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: 727 trans build part 1 [Re: ccdave] #17781
10/18/05 10:34 AM
10/18/05 10:34 AM
NC
440Jim Offline
440Jim  Offline
NC
I know a guy that does that 1/8" hole, but I have been using a 1/16" hole located directly behind the inner race, which then escapes to the rollers radially out. 1/8" just seems big to me, leaving less for the rest of the trans lube/cooling circuits.
That is a nice job cleaning the case. I hate cleaning the outside of the case.
440Jim's 727 Mod Tips
