Re: Need help finishing off inside of enclosed car trailer
[Re: Bigbeep]
#177576
12/30/08 09:46 AM
12/30/08 09:46 AM
Posts: 6,314 The Swamp
MegaDart
The Swamp
What did you use for trim on the floor, ceiling and top of carpet?
I reused the trim at bottom of wall/floor transition. Top of carpet I bought trim at home depot in the flooring dept. where I got the linoleum.
Do you glue the carpet on? If so, did you just use liquid nails?
Yes it is carpet glue that comes in 2-3gal buckets. Apply glue to area with notched trowel, then I would stick the carpet on and staple the top edge to prevent any movement while glue sets up. Apply trim.
[Re: StrokedW7]
#177577
12/30/08 09:53 AM
12/30/08 09:53 AM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
I aslo wondered if there wouldnt be some paint that I could use on the floors that would work or what about something like Rhino lining? Just thinking out loud.
Steve
I work for Rhino Linings and it is a bare to clean on an old floor if you have a oil leak. I personally would use the garage floor coating from Home Depot or U Coat It.
[Re: 65 Hemi]
#177578
12/30/08 10:28 AM
12/30/08 10:28 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Steve
This was the reason I put the diamond plate down on the floor, you dont have to worry if the paint will stick and also the plate is easy to clean even if you had a oil leak(blown engine)
[Re: MR_P_BODY]
#177579
12/30/08 11:04 AM
12/30/08 11:04 AM
Posts: 11,708 Portage,michigan
B3422W5
Portage,michigan
Steve...whats up?? Whats with the trailer? Are you actually going to take the car somewhere to race it??
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#177580
12/30/08 05:21 PM
12/30/08 05:21 PM
Posts: 2,333 Kalamazoo, MI
StrokedW7
Kalamazoo, MI
Steve...whats up??
Hey... No comments from the peanut gallery!!!
Hope things are going well and... congrats on engagment.
Steve
[Re: MegaDart]
#177581
12/30/08 10:25 PM
12/30/08 10:25 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
I put some pics of mine... I ordered it with cabinets/work bench,,floor treatment,,and wall/ceiling covering... I like the flooring,,,kinda marble like stuff,,linoliem ?,,,wipes up easy,,, I have since put down some more diamond plating running into the trailer,,,for the tires so they dont chew up the flooring ,,, Also put in a S4000 winch,,and a I-Home(25$) on ebay,,,so i can hear the announcer,,,and play my ipod...
[Re: 69CHARGERMD]
#177582
12/31/08 02:27 AM
12/31/08 02:27 AM
Posts: 19,360 Las Vegas
Al_Alguire
Las Vegas
Looks like 69Charger and I have similar tastes. I too have a Warn S4000 winch, but I went ghetto with the old boombox. Anyway here is my new one.. My old trailer I carpeted the inside floors. Actually I think I prefer the carpet to the linoleum I currently have. I was going to go with rubber coin but have a couple of buddies who have had it come up. On my wood floor I used some Home Depot trim on the bottom and for any entry point we simply used some aluminum angle.
