Need help finishing off inside of enclosed car trailer #177556
12/28/08 10:37 PM
12/28/08 10:37 PM
Kalamazoo, MI
StrokedW7 Offline OP
Kalamazoo, MI
I just picked up a used 28ft enclosed trailer. It is not finished inside. Where would be a good place to buy cabinets, etc.? Anyone done this? Any recomendations and/or pictures would be appreciated.
Steve
Steven M. Hamacher, CPA, MST
For ALL your tax, accounting, and payroll needs
www.Kalamazoo-CPA.com
Re: Need help finishing off inside of enclosed car trailer [Re: StrokedW7] #177557
12/28/08 10:59 PM
12/28/08 10:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Steve, are the walls done or is it studs and outter skin.
Home depot or maybe craigslist for cabinets. My old
trailer, I found some used cabinets local to me, a
guy was remodeling some apartments and he had a pile
to pick from then I bought a counter top at Home
Depot. If you need wall material I would call the
trailer places in Indiana. I just re-did my currant
trailer and bought the white alum for the walls and
ceiling(about $800 in alum)
Re: Need help finishing off inside of enclosed car trailer [Re: MR_P_BODY] #177558
12/28/08 11:04 PM
12/28/08 11:04 PM
Kalamazoo, MI
Kalamazoo, MI
Hi Mike,
Its just studs and outer skin... I actually thought about doing exactly what you did with the diamond plate on bottom. I was thinking I might be able to use the stuff that is used in bathrooms... that shiny white "stuff".
Steve
Re: Need help finishing off inside of enclosed car trailer [Re: StrokedW7] #177559
12/28/08 11:06 PM
12/28/08 11:06 PM
Kalamazoo, MI
Kalamazoo, MI
I aslo wondered if there wouldnt be some paint that I could use on the floors that would work or what about something like Rhino lining? Just thinking out loud.
Steve
Re: Need help finishing off inside of enclosed car trailer [Re: StrokedW7] #177560
12/28/08 11:19 PM
12/28/08 11:19 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Hi Mike,
Steve
I would consider plywood on the walls and then the bathroom wall stuff on top of the plywood.I have diamondplate floor but next time I would go with the rubber coin floor.Another way to do the walls is the plywood and garage floor paint on it or carpet halfway up.The plywood is important to hang all the crap you end up with on the walls and you dont have to look for a steel stud .
Re: Need help finishing off inside of enclosed car trailer [Re: cudabunch] #177561
12/28/08 11:25 PM
12/28/08 11:25 PM
Kalamazoo, MI
Kalamazoo, MI
Hi Mike,
Steve
Yes... I should have said that. Plywood is real important.
BTW - What is "rubber coin floor"
Steve
Re: Need help finishing off inside of enclosed car trailer [Re: StrokedW7] #177562
12/28/08 11:30 PM
12/28/08 11:30 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Its rubber with circles on the top very durable doesnt blind you when its sunny outside and can be found at home-improvement stores.Check out a race trailer website and you can see photos of it inside trailers
Re: Need help finishing off inside of enclosed car trailer [Re: StrokedW7] #177563
12/28/08 11:31 PM
12/28/08 11:31 PM
Kalamazoo, MI
Kalamazoo, MI
Do most people insulate the walls?
Steve
Re: Need help finishing off inside of enclosed car trailer [Re: StrokedW7] #177564
12/28/08 11:35 PM
12/28/08 11:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Hi Mike,
Steve
If your talking the white press board stuff... dont.
I tore that stuff down(I put that up first) because
if it gets wet.... it gets bad and buckles... but
I had a roof leak... which I fixed. I bought the
diamond plate from Jack Moore here on the board,
he's in the Columbus area.... very good price and
he also can get the white alum... I'd talk to him
FIRST. Make sure you insulate it also, I used 1"
of the blue styfofoam on the walls and ceiling
Re: Need help finishing off inside of enclosed car trailer [Re: StrokedW7] #177565
12/28/08 11:36 PM
12/28/08 11:36 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
I didnt insulate mine but the plywood is insulation enough if you get a air conditioner.PS wire the trailer for 240 before you do anything else.
Re: Need help finishing off inside of enclosed car trailer [Re: MR_P_BODY] #177566
12/28/08 11:47 PM
12/28/08 11:47 PM
Kalamazoo, MI
Kalamazoo, MI
No Im talking about the real thin shiny white stuff they use in bathrooms. You have to glue it to the walls. Im not sure if its actually plastic or not.
Steve
Re: Need help finishing off inside of enclosed car trai [Re: StrokedW7] #177567
12/29/08 12:05 AM
12/29/08 12:05 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
This is similar to what what my trailer looked like when new..
Then the mods..
1) Epoxy paint.. needed 2 gallons ($120-ish)
2) White paint on the wood panel, grey indoor/outdoor carpet on the lower half, trim and misc hardware ($200ish)
3) Cheap plastic cabinets from Home Depot.. ($175-ish)
4) Misc trailer caddy stuff bought from Summit Racing ($400-ish)
The trailer is still not finished, as I want to re-arrange stuff and install the tool box..
THE FLOOR
THE CABINETS
OVERALL
Re: Need help finishing off inside of enclosed car trai [Re: Jeepmon] #177568
12/29/08 06:25 AM
12/29/08 06:25 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
My trailer was pretty much finished on the inside, but I did add a bunch of E-Track and E-Track clips to the walls so I could strap stuff in easier.
Re: Need help finishing off inside of enclosed car trai [Re: 451Mopar] #177569
12/29/08 08:45 AM
12/29/08 08:45 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
the white stuff used in commercial bathrooms is Fiberglass reinforced panels (FRP). We normally glue it to drywall but it would adhere to plywood as well. It is fairly expensive. I would paint the walls white and use grey carpet up 3 or 4 feet. I don't think insulation is critical in your area unless you plan to use it in winter. If you are worried about too much heat do the ceiling
Re: Need help finishing off inside of enclosed car trai [Re: MegaDart] #177570
12/29/08 08:51 AM
12/29/08 08:51 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
Here is how I did one recently. Total cost of materials about $500
Re: Need help finishing off inside of enclosed car trai [Re: MegaDart] #177571
12/29/08 09:10 AM
12/29/08 09:10 AM
Kalamazoo, MI
Kalamazoo, MI
What did you use for trim on the floor, ceiling and top of carpet?
Do you glue the carpet on? If so, did you just use liquid nails?
Steve
Re: Need help finishing off inside of enclosed car trai [Re: StrokedW7] #177572
12/29/08 09:46 AM
12/29/08 09:46 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I had my floor painted with grey paint, but carpeted it last year. Makes it nice when the car is out as we often use the trailer for a living space at the track. I prefer the wood panel walls. Easy to hang stuff as mentioned, and won't scuff/dent easily like the aluminum interiors.
Here's some toys:
http://www.blazinbelltech.com/
I've bought a few items from these guys as they are right up the road from me in Vegas.
Re: Need help finishing off inside of enclosed car trailer [Re: StrokedW7] #177573
12/29/08 10:33 PM
12/29/08 10:33 PM
Kalamazoo, MI
Kalamazoo, MI
After looking at the trailer a little closer, the ceiling is not finished at all but the sides do have some thin wood on the walls. The ceiling is rounded... its a US Cargo trailer.
Any other ideas?
Steve
Re: Need help finishing off inside of enclosed car trailer [Re: StrokedW7] #177574
12/29/08 11:23 PM
12/29/08 11:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Any other ideas?
Steve
You can use luan, it'll form to the ceiling then cover it
if you want or paint
EDIT
Or you can 45* the wall to the ceiling, my old trailer
was like that, about 6" down the wall and 6" out on the ceiling
Re: Need help finishing off inside of enclosed car trailer [Re: MR_P_BODY] #177575
12/29/08 11:54 PM
12/29/08 11:54 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Plan your outlets and lighting while doing it. I wired mine a couple of years ago and just added a stereo this fall. I got tired of not being able to hear the track anouncer so I put a car cd/reciever in the cabinets with 2 speakers in the ceiling just inside the door. Next on my list is to install the 6500 watt Onan generator I scored on ebay for 350 bucks and plumb some air lines inside and out. Beep
