Jesel roller rocker #177260
12/28/08 06:42 PM
12/28/08 06:42 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Noticed some of these rockers come with an oil hole drilled from the top side where the oil puddles , into the underside which oils onto the valve retainer , should i carry this modification out? , or just rely on the oil 'overflowing' onto the valve/roller tip?
Should i fill this hollow in the rocker before i fire up , although the motor has already been broken in before i tore it down , i read jessel reccommend removeing the restrictor on a fresh build , will this apply in my case?
Rather than bring my previous post back up , am i right in thinking the lash cold is .005 thou less? , ie , hot .022 cold .017.
TIA.
Re: Jesel roller rocker [Re: 602heavy] #177261
12/29/08 06:08 PM
12/29/08 06:08 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
anyone?
Re: Jesel roller rocker [Re: 602heavy] #177262
12/29/08 06:47 PM
12/29/08 06:47 PM
I add .005.. things expand and move around ..Warm up to 180 and Re-tork and re-lash.. Leave rockers as they are, they will work fine...I always squirt some oil on the valve train before inital fire-up..
Re: Jesel roller rocker #177263
12/29/08 07:10 PM
12/29/08 07:10 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Thanks.
Got iron block/alu heads , so after reading previous thread i see how the lash setting is '005 tighter , was confused as i always used settings for ci block/heads.
Re: Jesel roller rocker [Re: 602heavy] #177264
12/29/08 08:11 PM
12/29/08 08:11 PM
Aluminum heads, according to Crane, should have the lash set .006 tighter when cold, reset after warming up the motor. some motors cahnge, some don't
Re: Jesel roller rocker [Re: Cab_Burge] #177265
12/30/08 12:13 PM
12/30/08 12:13 PM
mikemotorhead Offline
super street
super street
"should have the lash set .006 tighter when cold, reset after warming up the motor. "
Re: Jesel roller rocker [Re: mikemotorhead] #177266
12/30/08 12:40 PM
12/30/08 12:40 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Cold setting for start up .005 tighter.
