01 Ram trans dead and transfer case stuck to it. #1770982
03/04/15 03:26 AM
03/04/15 03:26 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Just to add a some expense to the deal the trans went out at 140K, had it towed to a shop, they cant get the transfer case off the trans it is corroded around the attaching studs so bad it wont come loose., and... the transfer case has a crack in it...
I will assume the crack happened when the rear axle fell apart at 30MPH and spit out the driveshaft while sliding to a stop.. a couple of months ago..
ARRG...
Re: 01 Ram trans dead and transfer case stuck to it. [Re: sthemi] #1770983
03/04/15 02:42 PM
03/04/15 02:42 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
CarPart is showing a few transfer cases close to you.
Mo' Farts
Moderated by "tbagger".
Re: 01 Ram trans dead and transfer case stuck to it. [Re: Grizzly] #1770984
03/06/15 03:39 AM
03/06/15 03:39 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Thanks,
Hollander parts has one pretty close, I am going to pick it up Saturday.
Re: 01 Ram trans dead and transfer case stuck to it. [Re: sthemi] #1770985
03/13/15 02:43 AM
03/13/15 02:43 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
got my truck back from the shop,
the trans internals were just a mess of worn and broken parts.
they had to soak the transfer case studs overnight to get it off the trans,
Re: 01 Ram trans dead and transfer case stuck to it. [Re: sthemi] #1770986
03/13/15 03:08 PM
03/13/15 03:08 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Not a very pleasant job to do, but hope it holds up and you get a pile of miles back out of it.
Mo' Farts
