Re: Electric fuel pump push fuel through a mechanical pump
[Re: RUNCHARGER]
#1769579
03/03/15 02:49 AM
03/03/15 02:49 AM
Posts: 1,990 s. e. pa.
calrobb2000
s. e. pa.
hi yes a elect pump wll push fuel through a mech pump . i have had mine that way for years . drain holley change jets hit switch ad refill carb before starting engine . 1 problem in hot weather mech pump will sometimes not pull enough fuel through elec pump for climing steep grades or w o t operation in which case i flip the on switch and prob solved .
[Re: RapidRobert]
#1769581
03/03/15 02:56 AM
03/03/15 02:56 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Something is wrong if you're having to prime the carb everytime you start your car. The carb should have gas in the fuel bowl without needing the pump to fill it each time. I can let my car sit for a month or more, and it fires right up with no choke, my setup is just a Carter street pump feeding a Holley double pumper. The question you should be asking is why is my carburetor empty and where is the fuel thats supposed to be in it going?
My 2-cents says you've got other problems. I wouldn't be suprised if you're dealing with a flooding issue, not lack of fuel (??).
[Re: RUNCHARGER]
#1769585
03/03/15 12:32 PM
03/03/15 12:32 PM
Posts: 11,991 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
It will work fine but you do not have to run parallel lines. I have a Holley electric back by the tank and it pushes through the mechanical just fine. I have both a manual switch under the dash for priming and the like and a micro switch that is actuated by the secondaries on the carb. That way, I don't have to listen to the electric pump all the time, but have the flow when I need it. This system has fed the Dominator on the street and track for years now.
Master, again and still
[Re: gdonovan]
#1769587
03/03/15 02:07 PM
03/03/15 02:07 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I looked at doing this and using a 5 second relay: ignition on, 5 seconds of priming, pump off, start engine, ignition off, ignition on, 5 seconds of priming, pump off, start engine...but the relays are 40 dollars each. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Challenger 1]
#1769590
03/03/15 09:32 PM
03/03/15 09:32 PM
Posts: 84 PA
Jack Zupan
PA
I have found using a stock enclosed air filter housing has slowed the evaporation of the fuel in my carb verses a open air, air filter.
What does this mean? Open vs. closed?
[Re: Jack Zupan]
#1769591
03/03/15 09:51 PM
03/03/15 09:51 PM
Posts: 30 Norcal
Wildjones
Norcal
I'm thinking he is referring to a snorkel type air filter as being "closed" and a K&N style as being "open".
