Hemi Vs Wedge Debate
#176814
12/28/08 12:17 AM
12/28/08 12:17 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
OK we have similar builds, compression 13:1+ Solid Roller setups. All good valve gear. Same style intakes with similar carbs. Lets say both engine heads have been fully ported in which the wedge heads flow around 380+cfm at .800 lift, with a larger 360CC port....The hemi heads flow a bit better 450-460cfm+ at .800 lift, with a way smaller runner. 240-250cc runner. How will the intake/head differences effect HP, and Torque between these engines? Which would have a broader Torque range... Will the wedge head seem to make more power up top? I have a good guess on power for the Wedge But wondering how a Hemi build similar would run
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: Hemi Vs Wedge Debate
[Re: Bob_Coomer]
#176815
12/28/08 12:23 AM
12/28/08 12:23 AM
A lot of varibles enter in to this...The main one is cubic inches..Are you talking 426H vs.440W or are we talking about motors with a 4.25 or 4.5 arm?
[Re: Bob_Coomer]
#176820
12/28/08 11:04 AM
12/28/08 11:04 AM
Posts: 614 Michigan
Get-X
This argument's been going on for about 80 years. I can tell you that when my car pulls to the line people come running. Having said that, I would turn my car off and get out to watch Chuck Millen's Wedge. It's personal choice, or more truthfully my Mom would disown me if I didn't run a Hemi.
I here that, great looking car, I would love to know your setup. The carbs etc. I will be running the same intake as you also..... Feel free to pm me about the entire car if you want... BTW I feel the same with Chucks car, never seen it run, but I know him personally, good people...
Add me to the list I too am building a 65 Belvedere with a 572 Hemi, Stage V big valves, Mopar x-ram etc...I'm a little curious what mods the intake needs. I know the plenum covers need to be fixed or replaced. Anyway, any insight or advice would be greatly appreciated
Marc
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: RAT PATROL]
#176822
12/28/08 11:33 AM
12/28/08 11:33 AM
Posts: 247 nc
moeflo
nc
Beautiful car!! and remember....Always listen to your mother.
[Re: moeflo]
#176823
12/28/08 11:47 AM
12/28/08 11:47 AM
The Hemi is going to make more bottom end power, but the wedge will be very reliable. Top end power is a toss-up...Wedge is cheaper to build....Hemi valve train pieces cost a small fortune.... I would build the wedge, but I may be a little prejudice, I run wedges...
[Re: Get-X]
#176824
12/28/08 11:54 AM
12/28/08 11:54 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
I'll add to the argument based on having street driven,raced,built,and tuned the fabled Hemis and Wedges in about every configuration,with the exception of T/F and only occasionally with nitrous .I can proclaim the in pure configuration in the right hands the Hemi gets my vote.Taking things to another level with all the R&D of wedge inspired techonology,the wedge engine have taken an edge.In certain venues where rules of modification limit or regulate the use of aftermarket techonology(class racing) the Hemi retains the edge.In pressurized(blown&turbo- charged) the Hemi will stand tall above all types engines.With all the new wedge or canted wedge style cylinder heads and manifold combinations the Wedges have a slight advantage,and are the popular choise.If someone wants to expound the time and effort to do some heavy Hemi R&D it would certainly be competitive to any engine if not reclaim it prestiges reputation of years past.The the word Hemi,the look,and the performance will make any nobody become someone to be respected.Take for instance four of my favorite all time big losers,Missle Kevin,HemiFred,Hemmeroidites,and the Yankee Fish Peddler.With out a Hemi they would be just four more flies on a pile of crap.
[Re: dizuster]
#176826
12/28/08 12:19 PM
12/28/08 12:19 PM
Posts: 12,379 Taxes & Virus's R-US, NY
Dragula
In the old days, when comparing 426 hemi to 440 wedge, the hemi was always quicker. Then you look at all the heavy cars in the 9's, and it was always them hemi's. The wedge engines were the ones in the 10's.
Now with the advent of all the R&D, both have got better, and both are capable of 8's in a nearly street weight car at 572 cubes, which is better...Does it matter at that level? I like both, and for me it would depend on the application and what I want to do with the car.
For my car, there was no other choice. I had a tunnel rammed 440 in the car, and nobody even noticed it. I put the hemi in it, and it became the crowd favorite. Other than the heads and pistons, they are pretty similar engines. Which is better, again depends on the car and the goal in mind I think.
[Re: dizuster]
#176827
12/28/08 12:33 PM
12/28/08 12:33 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
How come you guys think the hemi would make more low end torque? Not having specifics on the heads, something that flows 80cfm more has a larger port, meaning it needs more RPM to get the airspeed up. I would think the wedge would be better down low, and the hemi would make it upstairs...
narrower power band.
[Re: blownzoom440]
#176828
12/28/08 12:49 PM
12/28/08 12:49 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
The Hemi is easier to change spark plugs in plus they have a lot more factor
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: 67HEMI]
#176831
12/28/08 01:06 PM
12/28/08 01:06 PM
Posts: 12,408 Kalispell Mt.
HotRodDave
Kalispell Mt.
A hemi port does not have to be huge to flow like crazy, look at the new version hemi for proof, ports are no bigger than a SB head but can easily flow way over 300cfm like a heavily ported W2. The air flow has an almost direct shot at the back of the valve with a very long sweeping short turn it can make really fast and high volume air flow through a relativly small port.
All that being said I beleive with the factory valve positions an equally built wedge and hemi the hemi will always make more power. Now throw in all the canted valve wedges and moved centerlines and yes the wedges can keep up with the hemi.
BTW the comparison of the CC of the port is unfair because the Hemi has a shorter distance to the valve inside the head. A better comparison would be to compare minimum cross section in witch case the hemi will flow more in standard valve configuration.
The main reason the wedge is so popular is just because it is so much cheaper with only one rocker shaft and no spark plug tubes.
[Re: B G Racing]
#176832
12/28/08 01:40 PM
12/28/08 01:40 PM
Yep, my only input is, I have never seen a shirt that says;Yea ...It's got a Wedge
Sincerely, Kevin "The Fly"
[Re: HotRodDave]
#176833
12/28/08 01:45 PM
12/28/08 01:45 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
Seems pretty simple. If the hemi was the be all and end all of naturally aspirated engines they would be ruling the heads up classes of the world. I think we can all agree that they do not do that.
[Re: Al_Alguire]
#176834
12/28/08 02:17 PM
12/28/08 02:17 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
But at the same time we can all agree that no engine can compete with a Hemi in S S/S classes? How much hp does dthemi make N/A? (being a purpose built nitrous engine?)
[Re: RemCharger]
#176835
12/28/08 02:26 PM
12/28/08 02:26 PM
Al_Alguire
Las Vegas
SO now we are putting restrictions on the engines??? The SS stuff has plenty for sure. At best it means in a purely stock form that the Hemi had better heads. But I did not realize we were now restricting the engines to stock type heads. In that case I think we can all agree there is no comparison.
[Re: Al_Alguire]
#176836
12/28/08 02:37 PM
12/28/08 02:37 PM
Posts: 247 nc
moeflo
nc
This being titled "hemi vs. wedge", please share with us where a wedge is the preferred layout for any class, anywhere, unless the rules require it to be "inline valves".
I don't see how you can say an IHRA P/S engine isn't a hemi, but you can call a DRCE or a hemi 99 a wedge. Not with a straight face anyway.
[Re: Al_Alguire]
#176837
12/28/08 02:40 PM
12/28/08 02:40 PM
Posts: 1,141 Phoenix,Az.
hemicop
Phoenix,Az.
You've got to be kidding! The ALL-TIME heads-up classes. T/F, F/C & IHRA P/S all use Hemi heads. Whether they call 'em Mopars, Fords or now Chevys the design is still the same-- HEMI. When NHRA DID have heads-up P/S racing it was so one-sided they added weight to the Hemi cars & NASCAR flat-out banned them for a year until that political mess could get straightened out. Is A hEMI PERFECT? OF COURSE NOT! they're expensive, finicky, huge, heavy & comparitively complicated. But if price is no concern & you're not limited by rules or physical space, a hemi anything is the way to go.
[Re: hemicop]
#176838
12/28/08 02:45 PM
12/28/08 02:45 PM
Al_Alguire
Las Vegas
Your kidding right?? Did you miss the NATURALLY ASPIRATED part of the answer? Oh yeah this is almost 2009 not the 1970's Well being a guy who has run both Hemi and Wedge configured naturally aspirated Mopars I will not be going back to a Hemi, period. Well unless it is a 99 Hemi but who are we fooling that aint a Hemi anyway.
[Re: moeflo]
#176840
12/28/08 02:57 PM
12/28/08 02:57 PM
Al_Alguire
Las Vegas
I agree that at the top of the heap the heads are niether wedge nor hemi. Heck the only competitive and regularly winning Mopar I can think of is the Wedge -1 headed deal of Andy Mayes. He has now switched to a B1, I imagine if they thought they could win and make more power with a Hemi they would do it. In the ned there is not right answer to this question i am sure. It is one of those winter debates that goes on around here every year. We get off the wall statements from key board racers, opinions from those who have used both, opinions from professional engine builders and the question always goes unanswered. People prefer the engine type they prefer. I can only go on what I have tried. In the past two years I have ran two Hemis and two wedges and have formed my opinion. The weight of a Hemi piston and the cost of the valvetrain are enough to keep me in wedges for a good long time. FWIW there was more money in the 900hp Hemi I had than the 1041hp Wedge I now have.
[Re: Al_Alguire]
#176843
12/28/08 04:11 PM
12/28/08 04:11 PM
hemicop
Phoenix,Az.
Physics don't change with time & I DID mention some n/a types of racing. I've run wedges & hemis too & while I agree,to a point, 21st century technology is different, given the parameters I mentioned, there's no easy way to beat a hemi. It's not just me talking --- engine builders like Sonny Leonard, John Kaase, Arias Pistons & a few others, all (& in some cases still) use & develop hemi heads where rules allow. The BEST example is IHRA P/S --- no matter what the brand, some derivitative of a hemi head is used
[Re: hemicop]
#176845
12/28/08 04:29 PM
12/28/08 04:29 PM
Posts: 2,487 God's Country Maryland
GODSCOUNTRY340
What it boils down to is shrouding of both valves, intake and exhaust. Both valves in the wedge combustion chamber have shrouding, restricting flow. They are shrouded by the chamber along with the cylinder itself when the valve's open. The Hemi chamber doesn't have this problem, they are getting the full use of their valves and ports with no shrouding. This is the reason they came out with the canted valve heads, to alleviate some of the shrouding of the wedge head design.
[Re: B G Racing]
#176846
12/28/08 05:33 PM
12/28/08 05:33 PM
RemCharger
Sk. Canada
Kind of getting off track for a Hemi vs Wedge topic. Let's go back to pinion angles and 8-3/4 rearends.
8-3/4 =wedge 9-3/4= Hemi.
[Re: B G Racing]
#176847
12/28/08 05:44 PM
12/28/08 05:44 PM
Posts: 1,770 Pa
Wv68charger
Pa
i dont care who you are thats some funny chit right there
[Re: 8secDart]
#176851
12/28/08 07:43 PM
12/28/08 07:43 PM
67HEMI
As long as it is a Mopar I am ok with it. Just one question, how many all motor wedge cars that weigh 3320 or whatever SS/AH minimum is, have run 8.30's @ 157 with less than 440 inches? Not very many that I know of. They are either super light, have 500 plus inches,or have nitrous or forced induction.
[Re: Al_Alguire]
#176854
12/28/08 08:15 PM
12/28/08 08:15 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
funny, alot of n/a heads up classes ban the Hemi. I wonder why
[Re: HotRodDave]
#176855
12/28/08 08:32 PM
12/28/08 08:32 PM
Posts: 3,629 Oakland, MI
dizuster
Oakland, MI
Huh? A factory Hemi port is 1.84" x 2.00", thats 3.68 in^2. My fullly ported w9's are only 1.4" x 2.2" that's 3.08 in^2. My heads are 20% less port size then the hemi, and they flow about the same if not better...
(stock hemi port we're talking of course...)
The hemi head probably has the biggest port ever produced aside from the ford tunnel port stuff or a Ram Air 5...
[Re: Defbob]
#176857
12/28/08 09:01 PM
12/28/08 09:01 PM
Posts: 5,617 long island NY
Ari440
long island NY
the 440 wedge was never meant to be what the 426 hemi is
the block is weak 2 bolt mains small port heads
if the max wedge moter was built past 1964 the maxwedge head would have improved , instead it was dropped to build the 426 hemi
as migthy as the hemi is
the wedge head stands beside it
two diffrent engines
compare the 426 hemi to fords 427 - 429 hemi
1.39 9.85 - 137 mph
[Re: dizuster]
#176860
12/28/08 10:21 PM
12/28/08 10:21 PM
Posts: 247 nc
moeflo
nc
Huh? A factory Hemi port is 1.84" x 2.00", thats 3.68 in^2. My fully ported w9's are only 1.4" x 2.2" that's 3.08 in^2. My heads are 20% less port size then the hemi, and they flow about the same if not better...
Huh? A stock 426 port has less area than a BBC rectangle port, Boss 302/351/429 or Ford SCJ as well as the ones you mentioned. Normally I don't compare flow rates between OE and race heads, but if thats allowable, a 6.1 hemi can flow around 400 CFM with a 2-1/8th valve.
[Re: 67HEMI]
#176861
12/28/08 10:41 PM
12/28/08 10:41 PM
It might be very interesting to drop a 438 fully preped Max wedge motor in a SS/AH car..Of course use a sheet metal intake...Those cars have more tricks, ie.. suspension, trans/converter, weight disturbution than most would belive...The hemi would be faster due to the better factory heads.. I would bet the wedge would be well into the 8's as well
[Re: moeflo]
#176864
12/29/08 08:27 AM
12/29/08 08:27 AM
Defbob
Norwich CT USA
A popular misconception about the Hemi is that the valve train is trouble. I know that Pro Stock racer Warren Johnson has been a vocal critic of the Hemi and comments that with pushrods going this way and rocker arms going that way, it's not his idea of a promising configuration. Actually it is an extremely durable valvetrain. You've got alcohol dragsters running 10,500 rpm routinely and the parts last for years and years and years. I've got Stage V Engineering rocker arms on several competitive alcohol cars that are ten years old. I can't think of a better testament to the durability of the double rocker shaft design layout and validity Chrysler's execution.
- Eric Hansen
[Re: HotRodDave]
#176865
12/29/08 08:37 AM
12/29/08 08:37 AM
Posts: 247 nc
moeflo
nc
I don't know if a max ported W2 can flow 400 CFM
I do, and the answer is "no way".
but a ported 6.1 hemi head will and there not too far different in size, as best info as I can find on port size the W2 port is bigger. A more apropriate comparo would be the Max effort 6.1 Vs a max effort W8 assumeing you can get an aproprite displacement and or valve train for high RPM the hemi will make more power.
Two things other than the economy that are holding up race development of the 6.1. One is, it's not a Chevy. 30 minutes after the first LS motor hit the showroom, K Mart had several aftermarket head castings on the shelf. We're all used to that. Second, a 6.1 flow-wise takes a little more work to improve on than normal. The main weakness is the design and production of high lift valve trains. They will eventually come, but like a good 440 block, it will take a while. In the meantime, we'll keep hearing how a LS Chevy is sooooo amazing, how the LS motor is something revolutionary, etc., etc. But, when pressed, nobody can tell you exactly whats so revolutionary about them. But, we're used to that too. Stuff like this is why I'm not so big into hemi vs. wedge debates. I'd just like to see what is hands-down the best new line of V8's get a little support in the market. But, being a Mopar guy at heart, I've learned patience. I don't like it, but I've learned it.
[Re: moeflo]
#176868
12/29/08 10:49 AM
12/29/08 10:49 AM
dizuster
Oakland, MI
Sorry I thought we were talking about 426 hemi heads not new stuff... I was just making a point that the original hemi was BIG, and that's why a 450 cfm port would make less torque down low then the smaller wedge port.
As for new hemi stuff no doubt it's good. But I haven't seen any 400cfm #'s anywhere, 370cfm maybe, but not 400... Who's doing those?
And by the way you're right, I never realized how freakin' big a 302 Boss head was!!! LOL...
[Re: hemi_doug]
#176870
12/29/08 04:23 PM
12/29/08 04:23 PM
Dragula
Bob Reed says: "There are two types of people in this world, those who have Hemis and those who want Hemis".
I couldn't say it better myself!
He is wrong...there are acually three types of people....the two you listed and add to that the ones who have blowen them up....
Been there....spensive...
[Re: hemi_doug]
#176871
12/29/08 04:49 PM
12/29/08 04:49 PM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
You know, I've been racing Hemis since the late 60's and had exactly one (1) engine failure. In 1983 a rod broke, bent a couple of valves and busted the block around the pan rail. We sleeved two cylinders, put new valves in two cylinders, welded the block and raced that motor again the next weekend. That motor raced unti 2004, only putting in rings and bearings every couple of years. Don't give that unreliability crap. I've NEVER had a reliability problem, and I know that BG will tell you exactly the same thing. If someone does, it means they are overrevving it, which is totally unnecessary, or don't know what they are doing.
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
[Re: hemi_doug]
#176873
12/29/08 08:53 PM
12/29/08 08:53 PM
Steve1118
You seem to have had more problems than most have. A stock rod breaking....that is possible, that is why we generally polish and grind the sidebeams. Are you sure a bearing didn't get tight? As far as a bad spring....that is not even close to being the fault of engine design. Valve float is caused by overrevving it, the wrong spring for the application, or a faulty or worn out part. That is why you keep after that stuff in a race car. Any race car.....any type of engine. You still are not going to convince me that a Hemi is an unreliable piece, if built and raced correctly. If not, no design will survive. I have forty years of racing them that says you are wrong.
[Re: B G Racing]
#176874
12/29/08 09:32 PM
12/29/08 09:32 PM
How much h.p do you beleive an 8 3/4's can take,auto,no t-brake slant 6 without n.o.s. 4200 lb car with 15" slicks
[Re: hemi_doug]
#176876
12/29/08 11:18 PM
12/29/08 11:18 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
The 426 Hemi was a compromise from day one, it is not a true Hemi design with the valves centered over the cylinders. Look at the intake valve location, the cylinder wall schrouds it. Now for my on those that have had them and those that want them, be careful of what you wish for, Hemiroids are not for everyone I've had them, sold them, still build them but I race a wedge I'm probally one of the only Mopar racers that can't make as much power with a hemi than I can with a wedge
[Re: jdfpam]
#176878
12/30/08 07:21 AM
12/30/08 07:21 AM
Posts: 2,902 A shed in England
Tig
A shed in England
FWIW My buddy has a '70 gtx with an Indy headed 572 hemi. He runs a smaller cam (in the .690's to my .737) His car wieghs 200 lb less and runs 4:30's to my 4:10's. Both cars have 572ci, run 8 inch converters, single dominators, run on pump gas and have the same size and brand rear tyre. We both run caltracs and our 60ft are equal @ 1.39 best. He went 9.80 @ 139 and I went 9.79 @ 138.7 on the same day. He hasn't bested that yet but I've since gone 9.71 @ 140. I think his car would pick up HP with a similar lift cam to mine, I would obviously run a better et at 200lb less and with 4:30 gears. I think these cars would still be pretty close given the above but I still rib him that I would be infront When I first started out racing in '89, Hemi's were way expensive, you could build a higher HP wedge for the same money so I guess I've stuck with what I know. That having said a hemi does look really impressive in an engine bay but everyone expects a hemi to be quicker than a wedge. Advantage wedge in my humble opinion
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#176879
12/30/08 08:32 AM
12/30/08 08:32 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
I remember reading about Koffels creating the B1 engine, they ahd previously played with the Hemis, and according to that article their first B1 mule made 60 hp more than their best NHRA legal PS Hemi. I believe the last Hemi to qualify in NHRA PS was Reid Whistnant, maybe in 1987? When the rules changed I would have thought that Hemi would be The Choice in NHRA PS, but it wasn't competitive. The last one to try was Jeff Wick, he was usually about 0.3 seconds behind Alderman and his N...aturally aspirated B1. Hemi heads have the capability of flowing great, and if head flow is what you are lacking, then it's the key to producing more power. However, it is not so with all out smallish wedge engines. Current wedge heads flow well wnough, and the engines have volumetric efficiences in the 130% range. With that kind of volumetric efficiencies you don't benefit from better flow, other things become more important and the ones that will make the difference. In 1964 things were different, they needed flow and hte Hemi was the answer. Same is still true with "underheaded" engines, (usually very big displacement) engines with limited bore to stroke ratio. That's the only place where naturally aspirated Hemis still have an edge over even a conventional, modern Wedge like the W7,8&9's. If Hemi really were the answer, there would be nothing else.
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#176880
12/30/08 11:01 AM
12/30/08 11:01 AM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
I can admit that the Hemi isn't the answer for a heads up horsepower/dollar enviornment. But I like taking a unique motor and trying to do something with it. I think a big hemi has more character then a single 4 bbl wedge. However if i was doing a car that had the most horsepower / cube / dollar it wouldn't be a wedge. Id be in some tube chassis cobalt with chevy power.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: HemiDart68]
#176881
12/30/08 08:34 PM
12/30/08 08:34 PM
Posts: 247 nc
moeflo
nc
If you define "the most horsepower / cube / dollar literally, as things currently stand you just gave yourself zero choice other than a Roberts/Kasse Ford hemi or a Sonny's hemi (cough)Chevy. Well past center on the hemi-side of the wedge-hemi scale. Hemis, wedges, big and small blocks all have places where they shine. We can argue forever and that won't change.
