GEN III HEMI #1765807
03/01/15 10:58 AM
03/01/15 10:58 AM
ohio
Sherminator Offline OP
ohio
Looking at a 07 ram 3500 hemi with bad motor .What years will interchange
Re: GEN III HEMI [Re: Sherminator] #1765808
03/01/15 12:27 PM
03/01/15 12:27 PM
ohio
ohio
bump
Re: GEN III HEMI [Re: Sherminator] #1765809
03/01/15 12:58 PM
03/01/15 12:58 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
That all depends on if your engine has MDS or not. I don't recall the 2500/3500 trucks being equipped with it though. Either style engine can be changed over but will require removing the intake manifold and cylinder heads to swap lifters and MDS solenoids. EGR valve or not also makes a difference. 03-08 5.7 long blocks are the same otherwise.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: GEN III HEMI [Re: 71yelladustr] #1765810
03/01/15 01:21 PM
03/01/15 01:21 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
if u are looking to buy the truck, don't waste any $ putting a hemi back in a 1 ton truck, put a cummins in it and be done with it
Re: GEN III HEMI [Re: upnover] #1765811
03/01/15 06:47 PM
03/01/15 06:47 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
03-08 non mds
2500-3500 are all non mds, I beleive only cars had mds till at least 05 and probably till 08 so durangos and 1/2 tons should work also, there is some differences in elecrtonics over those years but all is swapable. All 03-08 hemis I have worked on have egr.
Re: GEN III HEMI [Re: HotRodDave] #1765812
03/01/15 06:52 PM
03/01/15 06:52 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
A cummins swap is VERY expensive, if you just have to have a cummins buy a cummins truck. You will need engine, trans, computer, springs, exhaust, harness, the computer will need to swap all the trucks computers and dash, inter cooler... basically a donor truck.
Re: GEN III HEMI [Re: HotRodDave] #1765813
03/01/15 11:16 PM
03/01/15 11:16 PM
ohio
ohio
The guy that owns it said the junk yard told him the serial number had to have a d in it .Maybe he meant mds ?
