Re: How to wire a starter relay 1971 Dodge Challenger
[Re: walley25]
#1763784
02/26/15 07:22 PM
02/26/15 07:22 PM
RapidRobert
Run a short jumper (1/4 female terminal/ring terminal) from the male "grn" terminal on the starter relay to ground (under SR mounting bolt works fine). this will allow it to crank in any gear position when you turn the key to start
