How to wire a starter relay 1971 Dodge Challenger #1763783
02/26/15 06:55 PM
02/26/15 06:55 PM
Canada
W
walley25 Offline OP
walley25  Offline OP
W
Canada
I am trying to find some information on how to wire or bypass the starter relay to the clutch safety switch and the neural safety switch on my 1971 Dodge Challenger manual transmission. I don't have the clutch safety switch and they are hard to find.
Any info or pictures would be appriciated.
Re: How to wire a starter relay 1971 Dodge Challenger [Re: walley25] #1763784
02/26/15 07:22 PM
02/26/15 07:22 PM
Run a short jumper (1/4 female terminal/ring terminal) from the male "grn" terminal on the starter relay to ground (under SR mounting bolt works fine). this will allow it to crank in any gear position when you turn the key to start
Re: How to wire a starter relay 1971 Dodge Challenger [Re: RapidRobert] #1763785
02/26/15 07:28 PM
02/26/15 07:28 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
It may cause more damage then a switch. Just 1 time you forget
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: How to wire a starter relay 1971 Dodge Challenger [Re: RapidRobert] #1763786
02/26/15 07:51 PM
02/26/15 07:51 PM
Canada
W
walley25 Offline OP
walley25  Offline OP
W
Canada
Do I have to worry about electrical shorts or fires running a jumper?
Re: How to wire a starter relay 1971 Dodge Challenger [Re: walley25] #1763787
02/26/15 07:59 PM
02/26/15 07:59 PM
No & if you need a new 1/4" female brass terminal the NAPA # is 725145 (99 cents ea )
Re: How to wire a starter relay 1971 Dodge Challenger [Re: RapidRobert] #1763788
02/26/15 08:17 PM
02/26/15 08:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
All the clutch switch does is ground the starter relay. There is a starter relay made to be self grounding for the manual trans cars that didn't come with the clutch switch.
Re: How to wire a starter relay 1971 Dodge Challenger [Re: stumpy] #1763789
02/26/15 08:31 PM
02/26/15 08:31 PM
Canada
W
walley25 Offline OP
walley25  Offline OP
W
Canada
Classic Industries makes a wiring harnass that incorporates the neutral safety switch and the backup lights. Can I use this harnass if I jumper to ground on the starter relay?
Re: How to wire a starter relay 1971 Dodge Challenger [Re: walley25] #1763790
02/26/15 10:38 PM
02/26/15 10:38 PM
Yes
Re: How to wire a starter relay 1971 Dodge Challenger [Re: RapidRobert] #1763791
02/27/15 04:36 AM
02/27/15 04:36 AM
Washington/Las Vegas
1971 Gran Coupe Offline
I would probably wire in a small toggle switch and put it on the bottom edge of the dash, below the light switch panel. It would be a momentary spring loaded switch that would not let you start (turn over) the engine until you actually hold the switch and close the contacts. As soon as it starts, and you let the switch spring back it will not engage if the key is turned until the switch is again pushed to allow it to start. This is a manual means taking place of the clutch safety switch. Yes those originals are hard to locate, bet brewers would have them though.
Re: How to wire a starter relay 1971 Dodge Challenger [Re: 1971 Gran Coupe] #1763792
02/27/15 05:41 PM
02/27/15 05:41 PM
Canada
W
walley25 Offline OP
walley25  Offline OP
W
Canada
The starter relay for the manual transmission cars have only one terminal on the bottem of the relay. Why only one whem automatic cars have two?
