I was just about to fit my new 489 centre with a Detroit Truetrac and guess what? The Truetrac assembly is not fitted with a thrust block to accept OE adjustable type axle bearings
So, I figure now is a good a time as any to convert to 'Green' type axle bearings (like it or not). I know there has been a quite a lot of controversy published in the past and there reliability is questionable however, of the two different types what is the preffered style........The Mopar style with the bearing and retaining plate as one unit OR the moser/strange style with the spirolox/circlip and seperate retaining plate?
Thanks MACKA
PS I will have to figure out a way down the track to run with the OE style if reliability becomes an issue!
