sixpac guys, HELP
#1755747
02/16/15 11:53 AM
02/16/15 11:53 AM
Posts: 12,008 Finally a HUSKER again
Moparnut426
So the thing runs fine when wormed up, but when cold it loads up like crazy, dosnt seem to ever clean out very well, I found that the choke is working, and I do have block offs in the heads, so is that affecting the whole thing? or is there something else I am missing. The plugs look good when hot and driving down the road it dosnt smoke. I do need to put the stiffer springs in the vacuum pods to slow the secondaries down, and I also need to add the bigger 50cc accelerator pump, but that stuff shouldn't bother the loading up idle...
Re: sixpac guys, HELP
[Re: screamindriver]
#1755756
02/17/15 11:48 AM
02/17/15 11:48 AM
Moparnut426
Thanks guys! Ill do this for sure. I know the choke is closed, and it was worm in the building the show was going on in. So with the choke closed and the temp high enough that the choke didn't need to be on Im sure that wasn't helpful at all. Appreciate it guys
[Re: GLR]
#1755759
02/18/15 11:07 AM
02/18/15 11:07 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I will have a six pack set up on my 383... I would like to use the heat block off gaskets so.....anyone know the correct part number of electric choke kit for a Holley six pack 2BBL carb?
That is something that does not exist !
[Re: GLR]
#1755761
02/18/15 12:42 PM
02/18/15 12:42 PM
62maxwgn
Blair County,PA
I just contacted Summit Racing, Yes..Holley does make an electric choke kit for the Holley 2BBL centre carb. This is the Holley Electric Choke Conversion Kit number 45-224 So... They do exist...
Wow,first time I've been wrong in about a week !!
[Re: GLR]
#1755764
02/19/15 03:08 AM
02/19/15 03:08 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
That kit will work great after you make a custom mount and linkage to clear everything. Holley does or did make a six-pac setup for smallblock chevies that had a different center carb casting, that had electric choke and looked like would work but I never bought one to try it for sure. Sell your carbs and buy a set of those and your problems are solved. Go to Summit and take a look at SUM-CSUM1900,go to the close up of the center carb, and you will see the mounting bosses your mopar carb does not have. I have done this on mopar carbs with the kit you mention, you just need to mount it with a bracket, make linkage, and hook up the vac line, works great.
[Re: Golden-Arm]
#1755770
02/25/15 08:44 PM
02/25/15 08:44 PM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
Im not quite sure you need all that stuff - theres a lot of tuning posts here - start there- i dont have any of that crap and my stroker starts wether its 20 or 90 .
[Re: GLR]
#1755776
02/26/15 12:41 PM
02/26/15 12:41 PM
Posts: 15,299 Omaha Ne
TJP
Omaha Ne
UPDATE: I ordered the Holley Electric Choke Conversion Kit number 45-224 as I was told by the SUMMIT Tech guy but ....................... It isn't even close to being able to bolt on
I called Holley first thing this morning and I was on hold with there technical line for 20 minutes but the guy I talked to told me that Holley doesn't make an Electric choke kit that will bolt on to a Mopar/Holley six pack centre carburetor. So I had some other carbs here and I removed an electric choke off an Edelbrock Performer carburetor that I had and two of the mounting bolt holes on the choke lined up with the mounting holes on the carb body, it is tight on the lower part of the choke casting but it still fit and I did remove a slight bit of material a little later once I knew the choke would bolt up. I had to make the arm on the back of the choke about a 1/4 inch longer (centre hole to centre hole) and re-bend the Holley linkage that came with the new centre six pack carb. It all works great and the choke clears the factory air cleaner also. I will attach pictures so that it can be done, with out a lot of trouble.
How are you going to address the choke pull off ??? IE: Edelbrocks use an internal vacuum source.
