Shackle Flip and towing a Loaded car trailer? #1751250
02/10/15 11:03 PM
02/10/15 11:03 PM
Iowa
76dodgeboy Offline OP
Iowa
Anyone on here do a shackle flip and tow a car trailer after?
I have a W200 I plan to lift 4" and already have front springs. Shackle flip is Roughly 4" but I'm worried that towing capacity will drop because the added Flex. Trailer is 16' and would at most haul a Clubcab Longbox. Thanks!
Re: Shackle Flip and towing a Loaded car trailer? [Re: 76dodgeboy] #1751251
02/11/15 12:22 AM
02/11/15 12:22 AM
ND
dodgedon Offline
dodgedon  Offline
ND
I have not done this type of lift but its my understanding that the side to side sway is a problem when its loaded down with a trailer. More of a control problem than weight. Now if you are using the longer Chevy springs than its a weight problem too. But as you know you can always upgrade spring packs....
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: Shackle Flip and towing a Loaded car trailer? [Re: dodgedon] #1751252
02/11/15 01:25 PM
02/11/15 01:25 PM
Iowa
Iowa
I've not heard if the sway issue. I know of a guy with a 89/90 Diesel that has Jungle Jim's shackle flip kit and he sled pulls. I'm thinking since their 1ton leafs that's his helping factor.
Re: Shackle Flip and towing a Loaded car trailer? [Re: 76dodgeboy] #1751253
02/12/15 03:44 AM
02/12/15 03:44 AM
ND
dodgedon Offline
dodgedon  Offline
ND
I would guess it just depends on what components you are using. But in general the longer the shackle the more side to side twist or (sway) you may have.
67 Charger 383 auto
Re: Shackle Flip and towing a Loaded car trailer? [Re: dodgedon] #1751254
02/12/15 05:56 AM
02/12/15 05:56 AM
Iowa
Iowa
Never planned for a longer schackle. Just the stock one.
Re: Shackle Flip and towing a Loaded car trailer? [Re: 76dodgeboy] #1751255
02/12/15 10:05 AM
02/12/15 10:05 AM
Pyeongtaek, South Korea
69HemiGTX Offline
69HemiGTX  Offline
I've been wondering the same thing. My crew cab is getting a Cummins 4x4 swap, and I'd like it to sit as high as a new one.
Flipping the shackle completely changes the dynamic and static loads it was designed for. It's now experiencing compression loads instead of tension, and everyone should know that metals are stronger in tension than compression. The added detractor is that the ability to deal with side loads is greatly diminished, simply because of the architecture. I plan on using custom springs to get the height I want and keep the shackles in tension.
I don't think towing a small load like a car and trailer would be too bad as long as you don't drive very fast and keep any sway under control. Make sure to keep the trailer's CG and tongue weight in check, too.
OIF V and OEF X veteran and proud of it!
Re: Shackle Flip and towing a Loaded car trailer? [Re: 76dodgeboy] #1751256
02/12/15 08:10 PM
02/12/15 08:10 PM
ND
dodgedon Offline
dodgedon  Offline
ND
I was just speaking in general.... Would you like to share with us your plan? I know there is many ways to do this.
67 Charger 383 auto
