Jeep guys, 4.0, WJ versus TJ #1748951
02/08/15 02:02 AM
02/08/15 02:02 AM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
Finally investigated why my Fiance's old 2001 WJ 4.0 quit last winter. Turns out it looks like it has the dreaded early "0331" cracked head at about 180K miles. I've found a 2002 4.0 from a TJ Wrangler. Fella is converting to diesel for his crawler and doesn't need the stock engine anymore. Do Wrangler and GC use the same 4.0 engine block in '01 & '02? So I could swap the 2002 Wrangler 4.0 into the 2001 GC directly? The '02 engine would get me the updated head, so the crack won't happen again.
Then my other choice. For about the same money ($700), I could buy a used '02-04 head + a light rebuild on the stock '01 short block. Lots of labor for me, but I'd know what I have when I'm done. If the short block is hurt (beyond bearings), this bet would be off because the cost would escalate.
Or, just swap in the complete Wrangler engine (100k miles) for the same $700 and hope for the best, quicker and less labor intensive. Either engine would get a new oil pump, front and rear seals and core plugs while the engine is out. Your thoughts?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Jeep guys, 4.0, WJ versus TJ [Re: GO_Fish] #1748952
02/08/15 11:35 AM
02/08/15 11:35 AM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
the engine should be a direct swap. 2000+ TJ and WJ used the same engine AFAIK
The XJ/early TJ block has different engine mount points if I remember correctly
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: Jeep guys, 4.0, WJ versus TJ [Re: ViperDave] #1748953
02/08/15 04:45 PM
02/08/15 04:45 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
Thanks Dave. I would have bet a small amount of money the WJ and TJ blocks were the same, but not $700. It was in the back of my mind that Wrangler 4.0s did have different engine mount bosses at some time in the earlier years.
Re: Jeep guys, 4.0, WJ versus TJ [Re: GO_Fish] #1748954
02/08/15 09:57 PM
02/08/15 09:57 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
it's the same, but make sure you get a good set of pics, or hand drawn diagrams, showing every switch, sensor and connector. there could be slight differences in these pieces, year to year.
Re: Jeep guys, 4.0, WJ versus TJ [Re: Golden-Arm] #1748955
02/08/15 11:56 PM
02/08/15 11:56 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
distributorless vs distributor come into play? I know the g.c. got them before the others.
Re: Jeep guys, 4.0, WJ versus TJ [Re: GO_Fish] #1748956
02/09/15 06:29 PM
02/09/15 06:29 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would drop it in as-is and not even crack it open. watch out for the sensors, sometimes connectors change year to year.
Re: Jeep guys, 4.0, WJ versus TJ [Re: DaytonaTurbo] #1748957
02/11/15 01:00 AM
02/11/15 01:00 AM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
I'm really torn on this. Not sure I even should put $700 in her old WJ and run it myself, or part it out & save its good parts for the WJ she's driving now. Money's tight now, hard do justify putting money into this when I don't really need another vehicle. Just that the WJ would be a little easier on gas as a work truck than the full size Ram 4x4 I'm running now. A few MPG better than the truck, but not a lot. Insurance on another vehicle? Uggg. Another vehicle to care for? Uggg.
