'72 - '80 Power Wagon, Where is the Backup Switch? #1748355
02/07/15 05:34 AM
02/07/15 05:34 AM
Rancho Cucamonga, CA
D_C Offline OP
D_C  Offline OP
I have a '74 W200 Power Wagon, 4-Speed Manual transmission.
The backup lights are not working. To trace out the problem, I am looking for the Backup/Neutral Safety Switch.
Where is it located/mounted? I see the Speedometer housing/cable is mounted on the Transfer Case. Is the backup there or on the transmission? I don't see any wires attached to either, and I don't see a Switch.
Thanks.
Re: '72 - '80 Power Wagon, Where is the Backup Switch? [Re: D_C] #1748356
02/07/15 02:31 PM
02/07/15 02:31 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
On drivers side, very top of transmission, in the side of the shifter housing.
You have a either a np445 or np435 transmission. There should be an ID tag on it
Re: '72 - '80 Power Wagon, Where is the Backup Switch? [Re: jerseybud] #1748357
02/07/15 02:42 PM
02/07/15 02:42 PM
D_C Offline OP
D_C  Offline OP
Thanks. I'll look for it there.
DC
Re: '72 - '80 Power Wagon, Where is the Backup Switch? [Re: D_C] #1748358
02/08/15 07:57 PM
02/08/15 07:57 PM
Rockford, IL.
Ruppman Offline
Ruppman  Offline
Rockford, IL.
like this I think.
Re: '72 - '80 Power Wagon, Where is the Backup Switch? [Re: Ruppman] #1748359
02/08/15 10:46 PM
02/08/15 10:46 PM
D_C Offline OP
D_C  Offline OP
I'll see if I can spot it. Thanks.
