Quench question... #174799
12/25/08 02:43 PM
12/25/08 02:43 PM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
How you calculate Quench when the deck height vary from .007 to .019 due to pistons rocking...
Actually if I use Cometic .027 my results are .034 to .046
Must I use thicker gasket
Re: Quench question... [Re: STROKIE] #174800
12/25/08 02:57 PM
12/25/08 02:57 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
As the engine gets up to temprature the piston to cylinder clearance tightens up so they will rock less...I normally take my measurment at the pin the cancel the effect of piston rocking...I would consider your .007-.019 as a .013 & your quench measurment is .040 maybe .039....As long as you let it warm up thoroughly before running it hard you'll be fine...
Re: Quench question... [Re: 1_WILD_RT] #174801
12/25/08 03:10 PM
12/25/08 03:10 PM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
I sended attachements...
4901140-Presentation1.ppt (127 downloads)
