Fuel Cell Size and Location #1747323
02/05/15 04:27 PM
02/05/15 04:27 PM
Tipp City, Ohio
Backfire Offline OP
Backfire  Offline OP
Tipp City, Ohio
I've lowered my '89 D100 2WD and I don't like how low the fuel tank is. It also interferes with building a dual exhaust system. Can You post pic's of your fuel cells in your trucks and give me any other advice that might help ?
Re: Fuel Cell Size and Location [Re: Backfire] #1747324
02/05/15 05:17 PM
02/05/15 05:17 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Here's my 85' with a RamCharger tank
That's the pump mounting bracket in the top of the pic
Re: Fuel Cell Size and Location [Re: BulletBob] #1747325
02/05/15 05:21 PM
02/05/15 05:21 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
That's 36 gallons & my gas gauge works as it is supposed to with no special stuff needed
Re: Fuel Cell Size and Location [Re: Backfire] #1747326
02/05/15 07:20 PM
02/05/15 07:20 PM
,Pa.
68dodge Offline
68dodge  Offline
,Pa.
here you go
Re: Fuel Cell Size and Location [Re: 68dodge] #1747327
02/06/15 10:25 PM
02/06/15 10:25 PM
scratchnfotraction Offline
Re: Fuel Cell Size and Location [Re: scratchnfotraction] #1747328
02/06/15 10:28 PM
02/06/15 10:28 PM
Re: Fuel Cell Size and Location [Re: scratchnfotraction] #1747329
02/08/15 02:44 PM
02/08/15 02:44 PM
Tipp City, Ohio
Backfire Offline OP
Backfire  Offline OP
Tipp City, Ohio
Thanks for taking the time to post your pics.
I didn't know about the Ramcharger tank.
I'll be looking for one at my local junkyards when the weather breaks.
Re: Fuel Cell Size and Location [Re: Backfire] #1747330
02/08/15 09:33 PM
02/08/15 09:33 PM
keep a check here in the truck parts for sale section.
a member has a couple tanks with cross brace.
I for get the screen name but he is out west. I will see if I can find his add or name.
I used a ferd couger 22 gallon gas tank with the ferd sending unit. it works a dodge fuel gauge in my truck.
it mounts in the same location as the RC tank with a little fab work and thinking.
Re: Fuel Cell Size and Location [Re: scratchnfotraction] #1747331
02/08/15 09:37 PM
02/08/15 09:37 PM
not to bad to install.
Re: Fuel Cell Size and Location [Re: scratchnfotraction] #1747332
02/08/15 09:40 PM
02/08/15 09:40 PM
124$ free shipping comes with the sender.
been trouble free since hook up. gauge is pretty close to correct. better than the stock sender in the 35 gallon saddle tank.
