diffrent lenght front drive shaft on a 1995 cummins #1744923
02/02/15 02:54 PM
02/02/15 02:54 PM
United states wisconsin
bigblockbryan Offline OP
okay heres my question i needed to replace my front drive shaft when i bought my truck it didnt have, so i bought one off a 1995 dodge 2500 extended cab with a cummnins with a auto. my truck is a 1995 regualr cab long box with a nv 4500 and the drive shaft is 5 inches too long to fit on my truck so has anyone else ran into this issue?
Re: diffrent lenght front drive shaft on a 1995 cummins [Re: bigblockbryan] #1744924
02/02/15 04:41 PM
02/02/15 04:41 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You are going to have to find one out of a 5 spd truck for it to fit. There are also different front u-joints depending on the year.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: diffrent lenght front drive shaft on a 1995 cummins [Re: 71yelladustr] #1744925
02/09/15 01:09 AM
02/09/15 01:09 AM
what if i changed the front yoke i i just pulled one off a 77 dodge and its the right length but the front yoke is diffrent width thanks
Re: diffrent lenght front drive shaft on a 1995 cummins [Re: bigblockbryan] #1744926
02/09/15 01:19 AM
02/09/15 01:19 AM
N
NITROUSN Offline
NITROUSN  Offline
N
No to small of a joint.
Re: diffrent lenght front drive shaft on a 1995 cummins *DELETED* [Re: bigblockbryan] #1744927
02/09/15 01:36 AM
02/09/15 01:36 AM
USA
Lawn Monkey Offline
Lawn Monkey  Offline
USA
Post deleted by Lawn Monkey
Re: diffrent lenght front drive shaft on a 1995 cummins [Re: Lawn Monkey] #1744928
02/09/15 05:05 PM
02/09/15 05:05 PM
Missouri U.S.A.
Missouri U.S.A.
Might be able to use a conversion u-joint to make it work. A Spicer 527x joint or equivalent could be the answer.
10.02@134
Re: diffrent lenght front drive shaft on a 1995 cummins [Re: 71yelladustr] #1744929
02/11/15 09:19 PM
02/11/15 09:19 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
might only cost $100 or less to shorten the one you have---make sure both ends fit correctly....
