What spring perches for truck 8 3/4? #1742159
01/30/15 03:24 AM
01/30/15 03:24 AM
woodcrest, CA
magnum440d100 Offline OP
woodcrest, CA
Going to be doing axle over spring to drop the rear of my 73 d100.
I see a couple different center pin hole sizes. I'm nowhere near my truck at the moment so I can't just go and measure anything.
What perches do I need? I'm using the stock 8 3/4 thanks in advance
Re: What spring perches for truck 8 3/4? [Re: magnum440d100] #1742160
01/30/15 08:29 PM
01/30/15 08:29 PM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
If I recall correctly I got mine from Mancini and my pin/locator was slightly larger than the hole in the pad so I threw them in the drill press and opened them up to fit. Just finished helping my cousin flip his and they fit with no modification...go figure .
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
