2011 Durango- brake light on dash coming on
#1739729
01/27/15 01:08 AM
01/27/15 01:08 AM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
The brake light on the dash of our 2011 Durango keeps coming on. This is just the red BRAKE light, not the ABS. What would be causing this?
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
Re: 2011 Durango- brake light on dash coming on
[Re: 11secaarcuda]
#1739730
01/27/15 03:12 AM
01/27/15 03:12 AM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
low fluid, excess wear in pads/rotors, malfunctioning abs system, proportioning valve hanging up. check the codes, using the plug under the steering column.
2011 had several recalls, for brake issues, on durangos.
[Re: Golden-Arm]
#1739731
01/27/15 03:03 PM
01/27/15 03:03 PM
11secaarcuda
WASHINGTON, PA
Is the code something that can be checked without going to the dealer?
[Re: 11secaarcuda]
#1739733
01/29/15 02:16 PM
01/29/15 02:16 PM
Posts: 21,063 Niles , Ohio
therocks
Niles , Ohio
Typically the red light wont set a code.The yellow ABS will.The red indicates low fluid brakes out of adjustment or real low pads etc.If the fluid is low enough to turn on the light it probally needs brakes.Most parts store readers can read an ABS code if they have a decent one.Rocky
Chrysler Firepower
[Re: Todd]
#1739735
02/01/15 06:05 PM
02/01/15 06:05 PM
therocks
Niles , Ohio
I forgot one other thing the park brake.I had one that just barely moved the switch and it would let the light come on.Rocky
Chrysler Firepower
