Re: Detroit area sandblast/paint stripping recommendation
[Re: 6pkaar]
#1739277
01/27/15 02:50 PM
01/27/15 02:50 PM
Posts: 11 Detroit, Michigan
njk53
Detroit, Michigan
International paint strip is a good chemical stripper at a fair price as stated by another responder. However, I would not chemically strip doors, hoods, or other components that have welded panels and little nooks and crannies. A buddy of mine ruined a set of clean Arizona doors because once the doors were cleaned and neutralized, the doors kept leeching the chemical stripper out of the seams and continuously ate the paint off of the bottom of the doors. It is difficult to get the stripper neutralized in confined areas so be cautious. But, for control arms, differentials, cylinder heads....solid pieces, etc. International Paint Strip does a good job and turn around time is pretty good too. There is a bead blaster (if you are stripping a complete body, doors, hood) in the Grosebeck & 15 mile area of Clinton Township called "Strip It All". They supposedly do a nice job also but, that statement is word of mouth. Not sure about pricing.
[Re: vinnyd76]
#1739280
02/13/15 10:27 PM
02/13/15 10:27 PM
Posts: 287 MI
AfterHoursResto
MI
SS Stripping is a great place to trust with your project. I have used one of the others mentioned in the past and ended up with warped panels. Cheap is not always better so be carefull! Fixing warped panels is not cheap. SS in Sterling Heights is always our first choice.
Roman Sobilo
[Re: AfterHoursResto]
#1739281
02/14/15 09:25 AM
02/14/15 09:25 AM
Posts: 9,814 MI, usa
dvw
MI, usa
I've used international with no issue. 3 different cars, one is still bare (way to long and looks ok), One in primer 4 years, ok, one finished 3 years, looks perfect. Don't do trunks or hoods because of the inner panel sealing glue. If you do have a "fat" seam on a panel, pry it apart before sending it. Then put Pour-15 in the seam and tap it back down when the part returns. Doug
