any tips fpr removing rusted v10 sparkplugs #1738021
01/25/15 01:19 AM
01/25/15 01:19 AM
Nashport, OH
chargers777 Offline OP
Nashport, OH
Looks like original equipment with 84,000 miles on them.I went to take the first one out and it broke leaving the threads in the head.I got them out but i dont want to go thru that nine more times.Any tips for getting very rusterd stuck plugs out?how about heat or maybe an impact to shake it loose?
Re: any tips fpr removing rusted v10 sparkplugs [Re: chargers777] #1738022
01/25/15 01:26 AM
01/25/15 01:26 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
PB blast it then try to tighten slightly to break it--- then loosen---i had a trailer flat and broke 3 rusted lug bolts in a row before i remembered the tighten slightly trick.....
Re: any tips fpr removing rusted v10 sparkplugs [Re: chargers777] #1738023
01/25/15 12:11 PM
01/25/15 12:11 PM
morrisville, pa
skajm Offline
skajm  Offline
morrisville, pa
Use anti seize on the threads before putting then back to prevent this in the future
Re: any tips fpr removing rusted v10 sparkplugs [Re: skajm] #1738024
01/25/15 01:10 PM
01/25/15 01:10 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
new cars with aluminum heads are coughing up threads all the time----beware---antisieze....
Re: any tips fpr removing rusted v10 sparkplugs [Re: chargers777] #1738025
01/25/15 03:21 PM
01/25/15 03:21 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Run it until fully warmed, drive it a while, then PB blaster or the sort around the plugs, let it cool, ... then pray. Tighten slightly, turn back and forth.
Anti seize on reassembly.
Might even want to warm and PB several times ... give the PB a while to work it's way in.
Good luck.
Think those are bad? Read up on 4.6 and 5.4 Fords ...
It takes gasoline to interest me.
Re: any tips fpr removing rusted v10 sparkplugs [Re: VL21] #1738026
01/25/15 10:05 PM
01/25/15 10:05 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
got a couple off before with the freeze stuff. pb blaster wasn't working.as said tighten then loosen
Re: any tips fpr removing rusted v10 sparkplugs [Re: chargers777] #1738027
01/26/15 09:34 PM
01/26/15 09:34 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Spray with penetrant and try to remove while hot.
Re: any tips fpr removing rusted v10 sparkplugs [Re: redraptor] #1738028
01/29/15 05:15 PM
01/29/15 05:15 PM
Nashport, OH
Nashport, OH
any plug recommendations if i do get them out?
Re: any tips fpr removing rusted v10 sparkplugs [Re: chargers777] #1738029
01/31/15 03:20 AM
01/31/15 03:20 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
I have removed dozens of broken plugs from 4.6/5.4. The best way is on a cold engine, try to loosen the plug 1/8th turn, then fill the spark plug well with carb spray and them sit for 30 minutes and try to remove them. On the ford engine the plugs can break 3 different ways, you need a removal kit to get the broken plug out. We service the county trucks and a fleet of 25 commercial ford busses. Thread repair inserts also are common on these engines. The best way I found is to let them soak on a cold engine and work the plug carefully trying not break them off.
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
