What P/S pump is this? #1737805
01/24/15 05:33 PM
01/24/15 05:33 PM
Ontario, Canada
D149 Offline OP
D149  Offline OP
Ontario, Canada
1968 Valiant 273. It should be a Federal 1.06, but this one looks very different from the service manual diagram, and any other Federal I've seen. Normally the pump comes apart from the back (inside the reservoir), but this one comes apart from the front. It was making noise and I want to rebuild it, but now I'm not sure I have the correct rebuild kit.
Any ideas?
1968 Valiant Signet 4dr. 273 4spd
1969 Road Runner 383 4spd
1969 Barracuda 318 auto
1970 Dart Swinger 340 4spd
1975 Cordoba 400-4bbl
1988 Caravelle 318 Auto
1999 Dakota R/T
2000 Viper GTS
2001 Ram 2500 Diesel 6spd
2018 Dodge Challenger GT (Winter beater!)
Re: What P/S pump is this? [Re: D149] #1737806
01/24/15 05:34 PM
01/24/15 05:34 PM
Ontario, Canada
D149 Offline OP
D149  Offline OP
Ontario, Canada
Back side of pump.
1999 Dakota R/T
2000 Viper GTS
Re: What P/S pump is this? [Re: D149] #1737807
01/24/15 05:35 PM
01/24/15 05:35 PM
Ontario, Canada
D149 Offline OP
D149  Offline OP
Ontario, Canada
Reservoir
1999 Dakota R/T
2000 Viper GTS
Re: What P/S pump is this? [Re: D149] #1737808
01/24/15 06:34 PM
01/24/15 06:34 PM
NC
1970A66 Offline
1970A66  Offline
NC
Based on this link (scroll down past mid point): http://www.dodgecharger.com/forum/index.php?topic=85087.0
You have a TRW pump
Re: What P/S pump is this? [Re: 1970A66] #1737809
01/24/15 06:40 PM
01/24/15 06:40 PM
Ontario, Canada
D149 Offline OP
D149  Offline OP
Ontario, Canada
Looks like you're right.
What is the TRW pump off of? It should be a federal on a '68 small block from what I understand. Are the brackets the same for Federal and TRW pumps? Are there any rebuild kits available for TRW pumps?
1999 Dakota R/T
2000 Viper GTS
Re: What P/S pump is this? [Re: D149] #1737810
01/24/15 07:40 PM
01/24/15 07:40 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
The brackets are different. Steer & Gear in Ohio has the rebuild kit you need. In '68 I believe many cars came either with the Federal or TRW/Thompson pumps. Saginaw I believe were used more in later years.
Re: What P/S pump is this? [Re: D149] #1737811
01/24/15 07:40 PM
01/24/15 07:40 PM
NC
1970A66 Offline
1970A66  Offline
NC
In this link: http://www.forabodiesonly.com/mopar/archive/index.php/t-180728.html read what BillGrissom has to say in his 3 posts.
If he is correct, a TRW PS pump is used with a cast iron water pump and brackets are not directly interchanegable between TRW and Federal. You would also have to get a different hose if going to a Federal.
Looks like Steer and Gear has seal kits etc for TRW: http://www.steerandgear.com/Chrysler_Catalog.html#TXTOBJ7DB1219F302938F0
I also read where someone bought a seal kit for TRW at rockauto.com
Re: What P/S pump is this? [Re: 1970A66] #1737812
01/24/15 07:51 PM
01/24/15 07:51 PM
Ontario, Canada
D149 Offline OP
D149  Offline OP
Ontario, Canada
Thanks guys.
I found a rebuild kit on Rockauto by looking up a '68 Chrysler big block. It shows the TRW pump.
1999 Dakota R/T
2000 Viper GTS
