Powerglide user Question #173503
12/23/08 04:08 PM
12/23/08 04:08 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
I would like to change over to a glide this winter and was wondering what internal mods do you feel are necessary for 750hp. in a pull tractor.
Post deleted by Defbob [Re: mac56] #173504
12/23/08 04:22 PM
12/23/08 04:22 PM
Re: Powerglide user Question #173505
12/23/08 04:39 PM
12/23/08 04:39 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
In a tractor not sure but I run a basically stock p/g with good band and clutches behind a 900 hp Hemi
Stock out and no straight cut gears? What ratio and does the ratio matter to strength?
Re: Powerglide user Question #173506
12/23/08 04:55 PM
12/23/08 04:55 PM
Get-X Offline
Get-X  Offline
Really? So basically just find a junkyard pg and change the bands and clutches and it's ready to go behind 900hps? No wonder people are changing over
'65 Belvedere
'68 GTX
'57 Dodge pickup
Post deleted by Defbob [Re: mac56] #173507
12/23/08 05:13 PM
12/23/08 05:13 PM
Re: Powerglide user Question #173508
12/23/08 06:24 PM
12/23/08 06:24 PM
CT
turbocolt2.4L Offline
CT
must be the 176 gearset.
Re: Powerglide user Question #173509
12/23/08 06:54 PM
12/23/08 06:54 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
stock gears
Stock stuff will not last in a pull tractor. Those things are basically in a constant state of tire shake. It won't be the power that kills a trans here, it will be the constant hook-no hook of the tires. This will take a good trans. I suggest aftermarket case, straight cut gear set, vasco input and a 10 clutch drum at the min.
Monte
Re: Powerglide user Question [Re: Monte_Smith] #173510
12/23/08 06:58 PM
12/23/08 06:58 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Fred I don't know how you get away with that.
I broke an aftermarket planetary with my 900HP small block that makes far less torque than your hemi.
Post deleted by Defbob [Re: Leon441] #173511
12/23/08 08:29 PM
12/23/08 08:29 PM
Re: Powerglide user Question #173512
12/23/08 09:04 PM
12/23/08 09:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The glide for my BB has the good input and output
shaft plus alot more inside
Re: Powerglide user Question [Re: Leon441] #173513
12/23/08 09:13 PM
12/23/08 09:13 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Anything can break Leon. I would not read much into the fact that you broke one. So far, out of all the trans that I have sold to guys, I have yet to sell one with a Vasco gear set. Just the standard, straight cut 9310 stuff and have not had a gear set break yet, even behind some blown motors. I have seen stock 1.76s hold up behind some real power, but you never know.
Monte
Re: Powerglide user Question [Re: Monte_Smith] #173514
12/23/08 09:49 PM
12/23/08 09:49 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I have heard of way more aftermarket gear sets breaking than stock 1.76 believe it or not.
OK
Will this have a break?
If so depending on what type of break, diff mods needs to be done (dump holes drilled etc.)
This lets the pressure dump off the reverse piston, which makes for a much quicker leave.
Use the good clutches, I used the thin ones about .070 thick compared to .100, which enabled me to get more into the forward clutch drum without milling etc. Which was about 7 in my case, but really depends on the piston style/thickness. Shoot for .075-.100 total clutch pack clearance total in the front drum.
The factory clutch hub, needs to be replaced, the factory is thin pop metal, and isn't wide enough to allow additional clutches.
Also ditch the servo piston for a duel ring setup, I never had any luck with the nylon/Teflon type, I prefer the cast iron ring style.
Get as many clutches as possible in the reverse side when using a Brake (extra Holding) if not running a break, just replace the clutches with same number high quality clutches, its not like your going to be racing in reverse LOL.
Replace the input shaft for a 300M or hard unit, I prefer the 350 turbo spline, better... read more choices, and finding used ones etc.
There is some pump mods that can be done too.
I done some simple mods as these, and I have had good luck using stock 1.76 gear sets. I pulled 1.07 60ft in a heavy dragster (1800-1900+ lbs), although they are light, it still had to take those 6K brake launches.
Re: Powerglide user Question [Re: Bob_Coomer] #173515
12/23/08 10:38 PM
12/23/08 10:38 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
OK
To answer at least one question. We do not use a brake. Just roll the throttle up on the converter sometimes faster than others but never flash or brake the converter.
Why 1.76 instead of 1.82? Is this only if you are using stock gears? I have heard stock output shaft can handle roughly 700 hp.
Re: Powerglide user Question [Re: mac56] #173516
12/23/08 10:50 PM
12/23/08 10:50 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Also I should add we only use low gear. Pull it into to low and full throttle until it won't go any further down the track.
Re: Powerglide user Question [Re: mac56] #173517
12/23/08 11:10 PM
12/23/08 11:10 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
The stock 1.82 is junk, hold a 1.76 and 1.82 next to each other and you will see. On a glide the planetary is the output shaft. My first one was a ATI somewhat high dollar piece that lasted 75 passes before exploding on launch, after beating it out of the trans we rebuilt it at the track with a stock 1.76 someone had. I ran the stock one for another 175 passes at 8.50 in a 2450 lbs car (still good at teardown). I then upgraded to a Hughes killer billet one and have had it in since (8 years?).
Cores. There are two ways to ID a 1.76 or 1.82 planetary trans. The input shafts are different lengths by .25" (14 5/8 & 14 7/8 I think) and the O.D. of the output shafts are different. Sorry I don't remember what they are at the moment but can look it up.
Re: Powerglide user Question [Re: TS3303] #173518
12/23/08 11:22 PM
12/23/08 11:22 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Thanks for the good info
Re: Powerglide user Question [Re: mac56] #173519
12/23/08 11:51 PM
12/23/08 11:51 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
the stock 1.76 seems to be quite strong. I bought a BTE 1.96 or whatever it was, it didnt last one run before all the gears crumbled.
The stock 1.76 worked fine before that, and after.
BTE still advertises them as having "no reported failures" however they warranteed mine but changed it to a 1.80. It still sits on the shelf.
Re: Powerglide user Question [Re: 5537SG] #173520
12/24/08 12:30 AM
12/24/08 12:30 AM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
I think some of the aftermarket gears are just too hard and the stock gears act like a rearend Pro Gear a little softer to take the sudden impact of those 6k launches off the brake
I wish I could find the pics of my ATI set, the gears exploded and locked everything up tight. I let go of the brake and it moved about 1" and stopped dead, glad it was a complete instant failure and didn't hang on till 2nd gear. I don't think there was one gear in that planetary that had all it's teeth still.
