Re: swapped the 11 inch discs in and now brakes are worse.
[Re: RapidRobert]
#1733338
01/21/15 10:31 PM
01/21/15 10:31 PM
Posts: 4,793 Castlegar, BC, Canada
That AMC Guy
no proportioning valve on this car. was a single pot master, and all I did was run dual lines. (I know, I know, I should add one, just never got around to it).
Well there's your problem! You need a proportioning valve for a disc/drum system to work properly. Without one (and a dual circuit master) all you're doing is *ahem* pushing rope.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: Andrewh]
#1733340
01/22/15 03:36 AM
01/22/15 03:36 AM
That AMC Guy
The rears not locking up is irrelevant. Dissimilar brake systems require a proportioning valve as disc brakes need higher pressure to function than drum brakes.
That's why I used the 'pushing rope' analogy - your trying to move something that requires 1000 lbs. of force with only 1 lb of pressure. It simply won't work.
A Proportioning valve and proper Dual Circuit master cylinder will give your car brakes.
You could always get an adjustable proportioning valve. That way, you can adjust it now for your disc/drum combo, but then later when you go four-wheel disc, have the added luxury of being able to adjust your front/rear brake bias.
[Re: Stanton]
#1733346
01/22/15 06:41 PM
01/22/15 06:41 PM
That AMC Guy
No prop valve ... here's how I see it ...
You apply the brakes, the rear cylinders fill and subsequently the m/c won't travel any further. Meanwhile the fronts haven't got enough fluid in them to do squat.
I'd be willing to bet that's exactly what's going on. With no proportioning valve, front/rear pressure is equal, but the discs require much higher pressures to operate correctly.
He's probably getting some brake action, but not enough to do squat.
To figure exactly what's going on, I'd need to actually crunch some numbers. I'd need cylinder diameters, caliper piston sizes, master cylinder size.... the numbers wouldn't lie.
He could also have a grossly undersized master. I must've missed the part where he said he had an aftermarket master.
